Question about Frigidaire Affinity ATF7000E Front Load Washer
Error message 20
Will not spin
  • 842 Answers
I THINK (but I'm not absolutely sure that E20 is the drain pump clogged. Hence the spin won't run, because there is still water in the drum because the pump can't get it all out in time. I know this model had a filter or trap for the pump, but I'm not sure where. I would guess a door on the front, bottom right?
If you do find the filter and clean it, then you may find that you need to leave the machine powered off and unplugged for an hour (or even overnight) to clear the error code.
Posted on Mar 01, 2009
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
"No Disc" error message
A no disc error on any electronics device indicates one of three problems. 1. The disc reading lens in the cd/dvd/brd drive has gone out or is dirty. 2. The drive has a "stabilizing" screw that must be tweaked. 3. The disc is not spinning due to a bad motor on the drive or something is blocking it. If you can hear the disc spinning *whizzing sound* its not a motor issue. You can try running a cd lens cleaning disc but if its not registering it probably wont spin, thus wont clean the lens. You can attempt to clean a lens with a cotton Q tip and rubbing alcohol but be warned, touching the lens can scratch it and destroy it. If your object is not under warranty you can have a professional look at the drive to check the tension on screws, this is usually a huge problem found in XBOX 360's. Make sure its not the disc by trying other working games/movies/etc. If all else fails you can always purchase a new dvd/cd/blu ray drive and have it professionally installed. Xbox 360 $20-$40, PS3 $100-$150 Although its not common, another solution is that cables on the drive might be loose, but usually you cannot open the device; the two cables are power approx. 1-1.5 inches long and the output plug which is usually half the size.
Jan 09, 2011 | Video Game Consoles & Games
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Error message LE
1. drain water
2. unplug for 20 minutes
3. spin the drum manually 3 rotations
4. back in business
look at this link below it has "Other" info
Mar 06, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
My washer does not spin out and reads error 20
don't know maybe moisture in the eletronics or outlet hose could be blocked, or it is out of balance
Dec 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
311 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
