Question about HP PSC 2210 All-In-One InkJet Printer
When I scan documens it does not scan it says that I have no place on hard disk. what happans?
  • HP Master
  • 5,568 Answers
Even with the size of hard drives we now have, it is possible to fill them, especially if you are using the highest resolution the scanner offers which is 4800 X 1200 dots per inch.  If you do just a little rough math, by my reckoning this comes out to a possible 465Mb for a single document.  A gigabyte is gone pretty quick at that pace.
You might want to take a look at the HP program that controls your PSC 2210 to find how you can reduce the resolution to something sensible.
Posted on Mar 01, 2009
My canon won't print colour or black ?
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Feb 06, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
When I ask my printer to print it just sits there and then the printer screen goes black?
hope this helps
Feb 06, 2011 | HP Photosmart C5280 Printer
I wont print anything
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 27, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Hallooo ... sp, what's the difference with the IR5570 IR 6570 .. thanks
-IR5570 : 55 page/mn
  1. 20 GB Hard disk drive
  2. 512 MB RAM
  3. Scanning resotion 600*600 dpi
  4. Copy resoltion 1200*600 dpi
  5. Print resoltion 2400*600 dpi
IR6570 : 65 page/mn
  2. 512 MB RAM
you can use this brochure to see more: http://www.usa.canon.com/cpr/pdf/Brochures/copier_ir_6570_5570_5070_brochure.pdf
Dec 07, 2010 | Canon imageRUNNER 5570 Copier
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
I have a acer aspire 8930g but wont boot up right it get stuck and it say "A disk error occurred" press Ctrl+Alt+Del to reset this is the first time this happen
If this happens each time you try to boot, the message is telling you that you have a hard drive problem.
First--is it still under warranty? If so, contact Acer or the place where you bought it.
Next--if it is not under warranty, I would suggest booting from a Windows CD/DVD and choosing the repair option--you will need to scan the hard drive for errors. If you get an error when you attempt this, you're going to have to replace the hard drive.
Dec 31, 2009 | Office Equipment & Supplies
No document in the copy of canon copier NP6317
Hi my name is Muhammad Kabir from afghanistan, I had a Nashuatec iR622J Copier Machine it had a paper jam problem and it was giving erorr massage to open left cover and remove the paper but when i was opening the left cover there was not even a small piece of paper inside of them even i checked the fuser unit but there was no paper what was the problem, the problem was with the sensors that they were not placed in their place and also the electricity lines had stoped the gararies of the fuser and when i removed them and put them in their own place the paper jam problem solved...if you need any more information please contact me this is my email id baktash_neumaticbeleive@hotmail.com
Best regards,
Muhammad Kabir Barakzai
May 11, 2009 | Office Equipment & Supplies
Xerox PE220 scan
you do it by install the driver and then the scanner cd and you have the possibilte to scan via pc
Feb 21, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
I have a document that I wish to email. How do I do that please?
Hello pepaga
The information you need will be based on the email client (software) that you use and on device that you use to scan a document onto your hard disk. Please, answer the following questions:
(01) Is the document on your hard disk already?
(02) Do you have only a hard copy of the document and you wish to scan it onto your hard disk and then send it as an attachment?
(03) What is the make and model of the machine (MFC, All-In-One, scanner) you use to scan documents onto your hard disk?
(04) What email client (software) do you use?
(e.g. Outlook Express, Outlook, Eudora, Thunderbird, Netscape Mail, etc.)
Please, post back here w/ your answers and any other info. that you can provide (the more details you can can provide us with the better). We'll do our best to provide you w/ the information you need.
Thank you
BJ
Apr 04, 2008 | Office Equipment & Supplies
HP PSC 2210 All-In-One InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
