Question about Kenmore 22422 Top Load Washer
My kenmore 90 series washer has a ring around the tub after wash
I'm loading the washer and using the correct amount of detergent. However, I seem to be getting a dirty ring around the tub after each completed wash. Can you help???
  • 15,935 Answers
Use He Detergent.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Itit suds then it stop wking
The SUDS or SUD error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click HERE for step-by-step instructions:
Nov 22, 2011 | Kenmore Elite 45986 Front Load Washer
Sud error on Kenmore Washing Machine HE3 King Size
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
CLICK
Oct 29, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Sud error comes on sreen
Aug 02, 2010 | Kenmore HE2 Plus Front Load Washer
My LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Jun 30, 2010 | LG Washing Machines
Soapy smell in clothes
You might need to wash your washing machine.
Most consumers think they are doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
This was a very big *faux pas* on LG's part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective if used the proper way:
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Got that? LOL
Jun 13, 2010 | LG WM2487H Front Load Washer
Screen flashing "LE" and will not finish spin cycle?
1) Musty Odor
front door gasket
May 24, 2010 | LG WM-2277HW Front Load Washer
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
May 19, 2010 | Kenmore Washing Machines
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 12502100 white plastic dusty residue
Sounds like washer mites. Put some cheese on the top of the washer after the load finishes. Then leave for at least 60 minutes. The mites will eat the cheese, be satisfied, and your wash will be good next time.
Jan 08, 2008 | Kenmore 12502 Top Load Washer
Kenmore 22422 Top Load Washer Logo
62 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
