Question about Kenmore Refrigerators
Kenmore side by side refrigerator (model 50542001)
This unit currently keeps causing the circuit breaker tripped. Just happened this morning. Do not why?
Could somebody help?
Thanks.
  • Anonymous Mar 16, 2014
    The refrigerator just stooped working. It had tripped the circuit breaker, but now the breaker is staying on while the refrigerator is plugged in, but nothing is coming on. Does the refrigerator itself have a breaker?
    Genius:
  • 1,122 Answers
THE SUSPECT YOUR COMP HAS LOCKED UP AND IS TRIPPING THE BREAKER,IF YOU HAVE A METER YOU CAN CHECK THE AMP DRAW,LOOK ON THE COMP. AND YOU WILL SEE THE LRA DRAW-MIKE
Posted on Mar 02, 2009
My maytag wadher model A7300 keeps tripping a circuit breaker. The drain hose fell off the sink, snd it got wet inside the the wadher. Is the motor blown or timer?
More than likely something has been shorted inside by the water intrusion. Anytime a breaker trips it is due to an over current draw situation. This happens when the power is shorted directly to ground causing too much current draw and the breaker trips in order to prevent a fire.
Oct 22, 2017 | Maytag Dryers
Tip
Circuit Breaker Keeps Tripping
Your circuit breaker keeps tripping and you are wondering why it would do that. There actually can be many things that can cause a circuit breaker to trip, or shut off. I will give you some reasons why circuit breakers trip and also some circuit breaker troubleshooting tips.
The first thing to remember about a circuit breaker is that they are first and foremost a safety device. The protection provided by the circuit breaker is also two fold. The circuit breaker will protect against overcurrent, or in other words, it will keep you from melting down the wires by placing too high of a load on any circuit. This would cause the wires to overheat and start a fire.
The other way a circuit breaker protects you is that the circuit breaker senses very quickly if there is current flowing to the ground with out it going through a load. This means that there is a shock hazard or a fire hazard. The circuit breaker will interrupt the current and shut off to prevent damage from happening.
If your circuit breaker is tripping off then you need to find out why this is happening. By eliminating the load on the circuit you can start to narrow down the possibilities. If there are a number of things plugged into the circuit then unplug something till it will stay on.If you can get the load low enough so that the circuit breaker stays on then you are okay and just need to spread the load out over a couple of circuits to prevent the overloading.
If you cannot stop the circuit breaker from tripping, unplug loads until you narrow the problem down to one thing. Once you narrow it down to one thing that is tripping the circuit breaker then you can find out why the load is tripping the circuit breaker.
Now if the load that is still plugged in is an appliance like a washing machine, then you need to find out if the cause of the tripping is the motor or if it is something like a wire that is rubbed through and is shorting out. If it is the motor the circuit breaker will often trip right when the motor goes to start up.
If the circuit breaker trips immediately when power is applied then you probably have a bad wire or connection. Poor connections are common in appliances such as an oven or a dryer where high amounts of current can be pulled at one time and the heat will make the connection get hot and eventually fail.
There are so many different possibilities for circuit breakers tripping that it is impossible to cover them all. There is one tool that will make the detective work of finding a short or problem much easier.This tool is called an "OHM" meter. One of these can be purchased at most any hardware or electrical store. Many big box stores and even a Wal-Mart also have them. There are many very inexpensive models available.
By using an OHM meter you can check the resistance of a circuit. The idea is that if a circuit has NO resistance to ground then it is bad and the electric can flow to the ground unhindered. This is a dangerous situation and must be corrected. In motors the flow of current between phases with no resistance, is also a reason why a circuit breaker will trip.
Above all remember that you need to verify and make sure that all electric is shut off to any piece of equipment that you are working on. Isolating and finding electrical problems can be very time consuming and frustrating. It will take time and patience to methodically eliminate the possible causes of a circuit breaker that keeps on tripping or a circuit breaker that will not reset. Through careful checking you can one by one eliminate the possibilities and find the cause of your circuit breaker not staying on.
on Oct 03, 2010 | Hammering
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
The power shuts off when i plug the fridge
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Refrigerators
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Frig trips circuit breaker
Hello gonzomg69,
The two other comments posed at you from Blue Dog and 20YRSEXP are good ones and necessary to get to the root cause of the problem however I have a few ideas to share with you that may help.. First off, I am assuming that the circuit breaker you mention is the one that protects the outlet that feeds your fridge power. If thats correct, and you just started to have breaker trips, the obvious question is ..does that circuit breaker also supply power to other receptacles and do those have any additional appliances or 'loads' on them that are drawing current? The circuit breaker current rating is based on the wire size so that regardless of what you plug into a receptacle, that breaker limits current so you won't melt the insulation or have a fire. Also, you should be aware that circuit breakers do go bad and that may be your problem too..
I hope this information helps you...
Regards,
Rick
Nov 28, 2008 | Whirlpool ET1WTKX Top Freezer Refrigerator
My ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Apr 20, 2008 | Heating & Cooling
Refrigerators Logo
317 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
