Question about Dell Latitude D600 Notebook
Display problems I have a Dell Latitude D600. The display has allot of lines and is patchy and the mouse has a ghost about 4 inch's to the right of the pointer. also the setup screen is not readable..I mean it is all garbled and not anything I can read. the numbers are ok but the letters are all messed up. I have updated the Readon driver and even reformatted the thing and re-loaded everything. the machine works...only problem is the diaplay issue. it is set to 1024X768 32bit. and it also looks the same on an external monitor. I suspect the video chip is trashed but I am not sure. what do you think.
    Problem Solver:
  • 6 Answers
Sounds like a fried video chip. I believe it's soldered onto the motherboard so if it is fried you would have to get a new motherboard. Part can be found here - http://www.parts-people.com/index.php?action=item&id=2739
You could probably take the part to any computer repair shop and they should be able to install it.
Posted on Mar 04, 2009
The cd drive will not open
some times... it you'll go to the control panel... and right click on the drive... and go to eject... it'll open... if it doesn't... replace the drive.
Apr 01, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 21, 2009 | Dell Latitude D600 Notebook
Wanted: replacement display screen - Samsung 14.1"
HI
You can buy from any of these.
http://www.google.com/search?rlz=1C1GGLD_enIN307&aq=f&sourceid=chrome&ie=UTF-8&q=D1002+dell
I have got almost 3.
Shopping results for D1002 dell D1002 - Dell Latitude D600 LCD Screen $149.97 - Renwerx Tech DELL D1002 LATITUDE D600 SXGA+ 14.1 DIS $253.75 - codemicro.com Dell D1002 LCD 14.1" TFT SXGA+ LATITUDE D600 $488.75 - eBay
Do let me know if you need further information. Its pleasure to assist you. And let me also inform you that can call Dell Spare Parts Sales and ask them to get this one for you. You get 90 days of warranty as well.
The part number is D1002 for the monitor.
Thank you
Rakesh
Dell Expert
Jan 06, 2009 | Dell Latitude D600 Notebook
From the keyboard how can i adjust dell latitude D 600 brightness
Hold down the Fn key and press the up arrow several times until it tops out. By default, if you are running on battery power, it dims the display to conserve power.
Oct 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Aug 23, 2008 | Dell Latitude D600 Notebook
Display not working properly
You should be able to plug in an external (Desktop type) monitor . Look for a connector on the side or back of the laptop. If the external monitor works, you have pretty much diagnosed that you have a LCD problem.
Ron-
Mar 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
102 people viewed this question
Alun Cox
