Question about Dell OptiPlex GX270 PC Desktop
Keyboard does not work
Can not type, keyboard does not work
  • Thomas F. Schneider May 11, 2010
    Try another keyboard to see if it ias the connection or the keyboard itself. You can also purchase new,inexpensive, keyboard at most discount stores. I
  • 28 Answers
Try first with working keyboard if not work check keyboard lock swicth or jumper or keyboard type selection jumper on motherboard
Posted on Mar 03, 2009
  • 54 Answers
Try with a known good keyboard
Posted on Mar 01, 2009
3 Suggested Answers
SOURCE: keyboard typing something other than the letters it should
Pressing the left control and shift at the same time fixes this for me.
Posted on Jun 03, 2009
  • 177 Answers
SOURCE: The keyboard stopped working. I was typing an
I have had this problem before. The solution was to clear the CMOS memory on the motherboard. The easiest way to do this is: Turn off and unplug pc from the mains. Open the case. Carefully remove the round lithium battery you see on the motherboard. wait 30 secs, then put it back in, close up the pc and turn back on. Note: If you have never done anything inside your computer before, you must be careful to touch as little as possible and be gentle. I hope this helps you.
Posted on Jul 17, 2010
Keyboard won't type
go to keyboard setting in device manager. check all keys if work properly. u might have your keyboard set to a different format
Oct 22, 2017 | Logitech G15 Gaming Keyboard
When type on keyboard nothing happens except beep from reciever
Hi if you look on back of keyboard their will be a small hole that has a button located inside its only small but have alook you should find it their is also one on the mouse alsso if this dont solve your problem then
Feb 07, 2008 | Fellowes Microban Cordless (98916)...
My @ is not working in the right place it works on the no 2 key
You are using a keyboard layout (software) that does not match your keyboard (hardware).
For example, if your keyboard is made for typing German, but you have activated a layout for typing English, the @ is not on Ctrl-Alt-Q where you expect it to be, but on Shift-2.
Solution 1: activate a keyboard layout matching your keyboard.
Solution 2: get used to the non-matching layout :-) There is a built-in utility to show a virtual keyboard onscreen. That will make it easier to find out how to type the various special characters.
Nov 27, 2012 | Dell Vostro 1000 Keyboard
I have sony vaio EB series laptop, my problem is that when I type 1 it type 21, when 3 it type 0.3, when 1 below f1 key it type 1 and open help window. there are other similar keys behaving same way. I got...
Hello
If the new keyboard is behaving same, then try to plug in an external keyboard to see if that works okay. You can use any USB keyboard. If this keyboard works, you have a hardware problem and need repair from Sony Support.
Hope this helps, Good Luck
Dec 31, 2010 | Sony VAIO VGP-WKB1 Keyboard
Gateway model KR-0817 WILL NOT TYPE I HAVE TO USE THE ON SRCEAN TO TYPE
Make sure the keyboard's "tail" is plugged-in to the _keyboard_ slot on the motherboard.
Try the keyboard on another computer, to see if it works at all.
Connect a "known-working" keyboard to your computer, to see if _any_ keyboard works.
Try a keyboard with a USB "tail".
Jan 22, 2010 | Gateway ML6720 ML6721 ML6725 Keyboard...
Locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 02, 2009 | HP DC170B Keyboard
Keyboard on gateway W323-UI1 does not work
yes the keyboard can be replaced on laptops and notebooks.
Apr 15, 2009 | Gateway (4000274) Motherboard
My half of the keypad(Right Side) not working
  4. Click Add .
  8. If required reinstall the drivers
Apr 15, 2009 | Computers & Internet
Trust keyboard and wireless mouse
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try typing to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Oct 23, 2008 | Trust Silverline Direct Access 12879...
Dell OptiPlex GX270 PC Desktop Logo
374 people viewed this question
Alun Cox
