Question about Toshiba Satellite M45-S265 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
My notebook shuts down in about 1 - 2 minutes after the system has booted-up. I do not know what caused this condition or how to repair. Please Help...
  • 523 Answers
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Posted on Mar 01, 2009
Toshiba satellite a100-ta7 system unit shuts off before boot .
try upgrading the memory module the observe for a quite sometime. if still, reformat your laptop by using the recovery disk.
Jun 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
System shuts down automatically
Turn on Laptop with F8 key or Delete key -
leave the computer on on the bios mode for few Minutes - see whether system turning itself of -
IF NOT - reinstall the OS
IF Yes - check the Hardware -
May 20, 2010 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Will not log off or shut down properly
sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
May 28, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Toshiba L 30 wan't booting
Remove or even replace cmos battery for 1 minute and should be back to normal. Worked for me.
Jan 26, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
294 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
