Question about Gateway 505GR PC Desktop
Wow almost a year later you respond the system is xp only on the older Gateway it does not go off the gateway screen I still have this computer I put it away but would love to be able to use it.
  • Dick
    Dick May 11, 2010
    Post a comment to your original question, this question makes no sense without that context.
    President:
  • 1,223 Answers
If it does not goes past the gate way screen then my firend check the hard disk is it connected and check in bios if its detected there other wise change ur hard disk and go
Posted on Mar 02, 2009
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
Windows XP on my Gateway PC will not accept Viewsonic Widescreen VA1912wSeries . My HP PC broke & I moved the montor to the Gateway. The HP had the same Windows XP system.
Reboot the computer into safemode. to do this tap F8 after the logo screen for gateway goes away. select Safe Mode.
Right click the desktop and click properties. in this window click settings. change the resolution to 1024x768.
click the advanced button. click monitor tab then set the screen refresh rate to 60 hertz.
if the monitor is compatible it will be able to be displayed. else try 1440x900 and 60Hertz for the settings
Feb 12, 2010 | ViewSonic VX2035WM LCD Monitor
Will power up but theres no picture
I'd first check that you have the hard drives installed correctly as you can have a primary and secondary drive ect. If you need any of the files I'm unsure but If you don't mind those files deleted you could reinstall windows xp. But from a different computer you could get the drivers needed for xp. Install the operating system xp for example and then from another computer dvd drivers such as network(Probably the most important) you can add those and reconnect to the internet and from there download the other drivers directly (IE video drivers). At least check the hard drive connections to see that they are the way you want them. Hope that helps somewhat.
Feb 07, 2010 | Gateway 550GR PC Desktop
Gateway computer - cannot boot up--
At boot up press F2 and enter BIOS. Here check if your HDD is recognized. If yes Ten your Windows is corrupted and needs to be reinstalled. How to install and save your data follow the link below:
Crashed Windows : No Problem
If the HDD is not being recognized then run Auto Detect to recognize the HDD. If it works fine, if not then the HDD may need a change.
Jan 25, 2010 | Computers & Internet
Replaced harddrive in Gateway 450rog and now wireless doesnt work
Simply reinstall windows xp over. I did it many times.
Mar 27, 2009 | Gateway 450ROG Notebook
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
Blue Screen
Is this still under warranty? If not then you'll just need to buy another HDD (hard drive device) and connect that one where the old was. Re-install XP or Vista. Conact Gateway or go to the Gateway web site to see what was hardware was supported for your system.
HDD IDE/EIDE or SATA/SATA II
OS XP or Vista
After you find out the info just install the new HDD, and install the OS. I only recommend doing this since you can't even get into the Safe Mode. When everything is back up and running you can also re-attach the old drive to what is called Slave or CS (cable select) this is more automatic process. Then you'll be able to recover any data missing that you need that was on the older drive.
Jul 30, 2008 | Gateway GT5404 PC Desktop
Older gateway
as far as the guy that added memory , if you do not have the memory cards installed all the way in ,the computer will act like that . Pull the sticks back out , check to make sure that there is not any dust or trash int he connections and put back in . You got to make sure that the sticks are completely in, and the tabs on the side of each stick are locked into the the notches .
Apr 03, 2008 | Gateway 505GR PC Desktop
Gateway 505GR PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
