Question about HP Officejet J5780 All-In-One InkJet Printer
Paper jammed - unable to see any paper in the machine
  • 2,120 Answers
Did you open the rear door and look?
Posted on Mar 02, 2009
3 Suggested Answers
SOURCE: I have had a paper jam
open the top lid and pull out the paper from the top
Posted on Feb 17, 2009
  • 142 Answers
SOURCE: paper jams near exit port unable to remove paper ,
Be gentle.
Please refer to OKI's recomendations for clearing a paper jam
Posted on Sep 06, 2010
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jam unable to find
Open the back cover door, clean the roller.
May 17, 2010 | Canon FAX-L360 Plain Paper Laser
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
Apr 08, 2010 | Brother Office Equipment & Supplies
remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
We are unable to load the paper on our Sharp UX-266 as the paper jam sign comes on every time we try it .
Unplug the machine open all covers and check for paper jams, remove the paper draw check for paper behind the draw. load paper before pluging in
Aug 15, 2009 | Sharp Office Equipment & Supplies
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
HP Officejet J5780 All-In-One InkJet Printer Logo
126 people viewed this question
Ben Johnson
