Question about Honda 6370C - Parallel Power Kit For EU3000i
Honda eu3000is won't start with starter.
Works on pull start. key on. has new battery. doesn't sound right
  • rbcane Mar 07, 2009
    I have same problem. Starts with pull starter, but will not stare with electric start. Starter moter makes a rough noise and sounds like it seizes up?? Can you help.
  • valvestem May 11, 2010
    Maybe not the what you are looking for but, was the new battery fully charged before installation? A weak battery in the EU3000 will makes the sounds you have described. I let my battery unattended for several months in my EU3000, when I went to start it, it made the noises same as you describe, I was nervous there for a minute.
  • 154 Answers
Replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
Posted on Jun 14, 2009
The electric start down not work
At risk of stating the obvious... Is the battery charged and/or connected? Does it at least click like it wants to start?
Jul 28, 2014 | Honda EU3000iS Inverter Generator
I have a 95 Honda civic and I was driving on the freeway went to get off and right when I was down shifting it wouldn't move out of neutral even though the stick was in the second gear position. So I...
To clarify something you said, the accessories should go off when the key switch is in the start position.
Are you getting power to the coil and the computer when the key switch is on and in start ?
May 30, 2013 | Cars & Trucks
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
My 2005 caravan won't start. When I turn the key I hear a clicking sound but it doesn't start. It worked fine earliar today.The battery is fine for now.
Possible causes are: 1. Loose or corroded battery cables. 2. Bad starter 3. Dead battery. Try tapping on the starter with a hammer while someone is holding the key in the start position. If it starts then replace the starter. Thanks
Sep 05, 2011 | 2005 Dodge Caravan
I have a 96 pontiac grand am that doesnt start all the time
Starting Problem # 1: Engine Won't Crank At All
Scenario: You turn the key, but nothing happens: And by nothing, we mean there is no dash light, no sound, nada. The first thing you should do in this case is to pop the hood and check the battery. Either the battery is completely dead or there's a wiring problem in the starting system. Try jump-starting the battery. If that doesn't work, you'll probably have to call for assistance.
Scenario: When you turn the key, you hear a rapid clicking sound, and the dash lights dim. This is your classic low-battery symptom. Jump-starting the battery should get the engine to start.However, if you keep experiencing this problem, you could have a bad battery or alternator, or it could be some­thing as simple as a loose alternator belt. Take your car to a mechanic just as soon as you can.
Scenario: When you turn the key, the lights on the dash come on, but you don't hear anything. Make sure you have the shift selector all the way in park. Move it out of park and then back, or try starting it with the shifter in neutral. If your car has a manual transmission, make sure you have the clutch pressed all the way to the floor. If that doesn't help, you can try jump-starting the battery, but it probably won't work. There's a good chance your car has a bad starter or a problem in the starting circuit. That could mean a prob­lem in the ignition switch, neutral safety switch or starter sole­noid.
Scenario: The dash lights come on when you turn the key, and then go right out, and the engine doesn't crank when you turn the key to start, But, the lights slowly come back on when you release the key. This is another classic: the bad battery connection. When you turn the key to start, the starter pulls so much current that it breaks the connection. Then, when you release the key, the connection slowly comes back. The connection provides enough power to turn the dash lights on, but not enough to crank the starter. Cleaning and tightening the battery terminals may fix this prob­lem.
Scenario: When you turn the key, you hear a single, hard clunk. Turn the headlights on and try again. Do the lights dim slightly when you turn the key? If so, you probably have a bad starter or a seized engine. If the headlights don't dim at all, or just barely dim, there may be a connection problem between the starter solenoid and the starter itself.
Scenario: When you turn the key, you hear a loud, scraping or grinding sound like metal on metal. The starter drive is bad, or the ring gear on the flywheel damaged, or both. You may get the starter to engage if you try turning the key a couple of times, but let go of the key right away if you hear the noise again. If the car does start, you should drive it right over to local repair shop and have the problem fixed.
Starting Problem #2: Engine Cranks but It Won't Start
Scenario: The engine seems to crank normally, but the engine doesn't even sound as if it's trying to start. Is there gas in the tank? Gas gauges are notoriously inaccurate. If you have to move your head to one side to get the needle to move off empty, try adding some gas to the tank.
Scenario: When you first turn the key on, you don't hear the fuel pump run. In cars with electronic fuel injection, you should hear a light hum a few seconds from around the fuel tank. That's the electric fuel pump running. If you don't hear the fuel pump run for a couple seconds when you first turn the key on, try cranking the engine until the oil light goes out. That may start the pump running and allow the engine to start.
Scenario: The engine cranks normally, and it sounds like it wants to start, but it won't. You may have flooded the engine. Hold the gas floor and try again. (Let the gas pedal up when it finally starts). If it's raining out, the ignition system may be wet.
Scenario: The engine cranks unevenly in a repetitive-sounding pattern. You may have a bad timing chain or timing belt. Call a tow truck and have it towed to the repair shop.
Starting Problem # 3: Engine Starts but It Shuts Off
Scenario: The engine starts right up, but shuts off as soon as you release the key. This is the classic symptom of a bad ignition switch. A new switch should fix it.
Scenario: The engine starts and runs, but when you put the transmission in gear, the car lurches and the engine shuts off. The converter clutch in the transmission torque converter probably is engaging when it shouldn't. On some cars, you can bypass this by disconnecting the torque converter clutch solenoid; but unless you know which wire to pull, forget about it. Call for assistance.
Scenario: The engine starts and runs, but seems to idle slowly and stalls when you come to a stop. This probably is a fast idle problem. When the engine is cold, it's supposed to idle a little faster than normal to keep the engine running. You may be able to drive using two feet until the engine warms up: one on the gas to hold the idle up a little and the other for the brake. However, don't keep driving it this way. Take your car to your repair shop just as soon as you
Jul 21, 2011 | 1996 Pontiac Grand Am
Honda EU3000is. 2 year old unit used by electric start at least 5 days a week. My gen has recently stopped staring by the electric start, it turns over but just not as strong as when new, what i mean by...
I have a 5 year old EU300is that would not start with or without the battery. I went through all the usual such as gas, plug, oil, etc. The battery showed 12 volts, however, when tested further it would not hold a load. I bought a new American made battery and now the unit runs fine.
Jan 29, 2011 | Honda 6370C - Parallel Power Kit For ...
Honda eu3000is runs fine with pull cord, but when you use the elec start the starter motor turns but will not engage.
Probably the Bendix needs lube. This is the spiral that the pinion gear runs on.
Remove the starter and inspect to insure the pinion gear is in good shape and the bendix is free to move. also verify that the solenoid throws the pinion out to engage.
You can bench test the starter to verify operation.
Also check condition of the ring gear via the starter mounting hole.
Apr 11, 2010 | Honda 6370C - Parallel Power Kit For ...
Broken pull cord install instructions
Hi there .
The only way to get to the starter on a EU3000IS is from the front of the machine .
You have to remove the plastic around the control panel , remove the control panel and the inverter and you be able to see the starter on the right side . To remove it is only 3 10mm bolts holding it in place . Make sure when you put it back is on the right place and pull the cord gently so the starter can sit .
Hope this help
Jul 12, 2009 | Honda 6370C - Parallel Power Kit For ...
Need a battery for honda eu3000is
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
Mar 28, 2009 | Honda 3000 Watt Portable Generator
Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Mar 08, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda 6370C - Parallel Power Kit For  EU3000i Logo
2,221 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
