I have an iPod Touch and I have been trying hopelssly to connect to the wifi. I have a BT Voyager 2110 router. I have been putting in the right password and it even says I am connected as it has a tick beside the SSID and there are 3 bars at the top. The IP address and the Subnet Mask are also filled in. However when I try to use safri etc it says I am not connected please help!
So what is the IP Address that the iPod Touch gets? Does it match with what range the BT gives out?
Does anything else connect through that router successfully?
You might try changing the WEP, WPA, WPA2 that you are using ... see if that helps the iPod touch to connect. I've seen where certain computers, etc. do not like WPA or WPA2 or certain passwords or key codes.
Wish to connect router to New PC on Win 7 and also to existing PC on Win XP Step by step process. Am...
(More)
Wish to connect router to New PC on Win 7 and also to existing PC on Win XP Step by step process. Am on broadband cable with Talktalk
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless...
(More)
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access Point is the Thomson SpeedTouch and the repeater/secondary router is the Netgear DG834Gv3. So the Thomson SpeedTouch is the one connected to the phone line and currently has internet. I am with O2 Broadband UK. The Netgear router has the latest firmware. I would be very greateful if anyone could please help me.
