Question about Gateway GT5242E PC Desktop
Video is purple
On the monitor video is purple instead of blue, monitor and cable work fine when attached to another computer. thank you
  • suemarney Mar 02, 2009
    Thank you for confirming what I thought it was. I tried downloading a driver update but it did not help... it is the VGA card. Thanks again for responding. S
  • 1,223 Answers
It is typical hardware problem of vga card check is it in built or what u can use another vga card buy a new one according to ur system and it will be resolved , also first check that at the vga terminal all holes are ok in the socket nothing is stopping the vga pins to go in socket otherwise u socket on the vga card is faulty u can get it replaced and check if u like but it is not a software issue i am sure its an hardware issue i told u the solution
pls rate me fixya if i fixed ur problem
Posted on Mar 02, 2009
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try or
Mar 17, 2011 | IBM ThinkVision L170 17" LCD Monitor
When i switch on my pc the monitor display a blue power light for 5 seconds and then it turns to orange and nothing displays on screen.
Make sure you have connected the Video cable properly, Please disconnect the Video cable from the Computer and connect the monitor only to the power source. If you monitor shows anything like "Check video cable" or "No Signal" that means the monitor is working fine. You just need to connect it properly to the computer
For any further assistance feel free to get back with your comments .
Thank you for choosing Fixya
Nov 01, 2010 | Acer V193w LCD Monitor
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
Screen is flashing and buttons dont work.
Check the video cable first.
Try connecting to a different computer.
If the cable is not causing the problem, then you have a faulty LCD controller board or a defective input signal board (the one where you hook up VGA/DVI cable). The LCD panel ribbon cable must also be tested or replaced.
PSU, Inverter and LCD panel are not faulty for sure.
May 28, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
Feb 12, 2009 | Dell Dimension C521 PC Desktop
Monitor Problems
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Sep 09, 2008 | Dell E207WFP LCD Monitor
My Monitor al1916w the color is all purple or blue. No other color appears including white,yellow or red. please help.
Aug 11, 2008 | Acer Computers & Internet
Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
Dec 26, 2007 | Dell E176FP 17" LCD Monitor
Gateway GT5242E PC Desktop Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
