Question about Troy Bilt Tb70ss Gas Trimmer
Pull Cord won't pull on model TB525CS
Can't start weed eater. Cord pull very samall amount and the seizes. I've taken off the shaft and throttle but can't get to the cord assemble. Please help
  • schultz_greg Mar 25, 2009
    I returned it to Lowes as it was less than 1 year old, and they gave me a brand new one. (much easier fix for me...)
    Thanks for the good info anyway. Never know when I might actually need to get my hands dirty
2 Suggested Answers
moretons
  • 155 Answers
SOURCE: Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Posted on Jul 26, 2009
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
    Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
    Sep 23, 2012 | Garden
    Weed eater made a noise then just quit working, pull cord wont engage
    hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
    Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Replacing pull cord on weedeater
    there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
    Aug 06, 2009 | Ryobi Garden
    Repalce the pull cord a Craftsman Weed eater 32CC
    I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
    Drew
    Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
    Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Troy Bilt Tb70ss Gas Trimmer Logo
    765 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
