Question about Protron PLTV3250 32 in. LCD Television
TV went dead in the middle of a program. Cannot turn it back on. The power outlet checks out find.
  • 6 more comments
  • katerr757 Mar 01, 2009
    It is a Protron 32" LCD TV. No the led light is not on
    Thanks, all. We will look into the power supply.
  • rmjamieson57 Mar 02, 2009
    tv went dead and it wont turn back on.
  • TRIPLESCHAB Mar 06, 2009
    HOW DO i GET TO THE POWER BOARD (WHERE IS IT LOCATED) AND IS IT TOO DIFFICULT FOR A TOTALLY TECHNILOGICALLY CHALLENGED PERSON TO REPLACE IT?
  • Anonymous Mar 22, 2009
    tv is dead took apart saw 3bubbled caps changed but still completely dead
  • dahlbep Mar 30, 2009
    My father has teh same problem. Are the capacitors separate formt eh power supply? If so how you find the correct replacements?
  • mikedadof2 Apr 06, 2009
    same problem here, watching a program and tv went dead. no power to tv at , tried different outlet still tv does not work.
  • javswr
    javswr May 11, 2010
    What kind of tv? Is the led light blinking? Is the screen black?
  • 44 Answers
I agree with localwonder!! Itsounds like you have a power supply problem! You will probably find some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain).
Posted on Mar 01, 2009
  • javswr
    javswr Mar 01, 2009
    You can buy a new power supply from www.shopjimmy.com, they have 121 power supplies in stock! Use the brand and your model number! Good luck!!
  • 6,784 Answers
This is a typical power board failure. you can make sure by unplugging for 5 min to reset the entire board. if it still wont come on, its the power board. considering how this set just shut down, it is most defiantly due to a over heating situation that has blown the capacitors on the power board.
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Died, no light indicating getting power
Check ur power source outlet?Yes than ur power supply board,that the board ur a/c power cord go into it.That the power supply board,it dead.Take ur tv aparts and replaced the power supply board,ur tv will have power back and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 25, 2010 | Vizio L32 32 in. LCD HDTV
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
TV DEAD
hello, the first thing to do is to check the power supply, meaning check the main fuse and burned components,if do not have any electronics repair skills call the repairman, but first carefully open the set and check the all the fuses.
Dec 19, 2008 | Protron PLTV-32 Television
Television Went Dead
When you first turn it on dose the LED blink? if it dose then maybe the inverter board went bad if the LED don't blink then maybe power supply
Jul 10, 2008 | TruTech PLV16320 Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV3250 32 in. LCD Television Logo
254 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
