Question about Nintendo Wii Fit for Wii
Wii remotes got unregistered by wii fit
My brother brought his wii board over and I tried to sync it to my system then come to find out it unregistered my remotes and I cant get them to work now.
Just press the sync button on remote and then on the console and should buzz!
read wii setup again that will explain it better!
Posted on Mar 01, 2009
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    I can't sync my board to my remote
    You have to insert a wii fit game and bypass all the stuff until the game is ready to play.Open the battery compartment on the Wii board and open the large door on the front of the Wii console.Press the sync button on the board,then press the sync button at the top of the console compartment.The fit board light should stay steady blue.If it doesn't,try it again.When the fit board stays steady blue,it is synched.
    Jul 13, 2010 | Nintendo Wii Fit for Wii
    I am having probelms getting the board to sych with the box please help !!!!
    Simply turn on your Wii. Using the first player remote press the home button then go to the bottom of the screen and you'll see the controller sync screen. You should then see like a resync or something similar. Hot that and the Wii will make two ringing sounds. When this happens press and hold the 1+2 buttons on the remote and then after it connects press and hold the sync button on the Wii Fit board where you insert the batteries.
    Feb 01, 2010 | Nintendo Wii Fit for Wii
    Wii fit board won't work
    Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
    The exact procedure is:
    • Even if the battery level is strong, try the following:
    Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
    Try these steps!
    1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
    Hope it helped.
    Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
    We used our wii fit on another wii system. After
      Try these steps!
    1. Insert a Wii Balance Board compatible game disc in the Wii console.
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
    If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
    Hope it helped.
    Nov 22, 2009 | Nintendo Wii Fit for Wii
    I have a wii fit and tried to sych it to my console. I think I held the sych button on the balance board too long and messed up the remotes. They won't work at all now. Please help! Thank You
    Ensure your batteries are fresh. Ensure that the Wii Fit (or other Balance Board game) is started up completely before pressing the power button. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the will console for about 4 seconds. You will have to re-sync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Oct 18, 2009 | Nintendo Video Game Consoles & Games
    Unable to sync Balance Board and its knocking the remotes out too
    When you are prompted to press the sync buttons you just have to press and release just once the sync button on the console and then on the board. Do not hold the buttons in because you just end up un syncing everything!
    Dec 27, 2008 | Nintendo Wii Fit for Wii
    Cant sync wii balance board
    I know it's been a while since you have posted and have prob already figured it out. But just in case this may help someone else. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the wii console for about 4 sec. You will have to resync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Nov 17, 2008 | Nintendo Wii Fit for Wii
    I was trying to register the Wii Balance Board for my Wii Fit. I think I may have presses the sync button on the Wii console too long and caused my Wii remotes to become unregistered. How can I correct the...
    Hey wva54ccc,
    According to information provided by the manufacturer, holding the sync button down for a prolonged period does clear all synced devices from the Wii's memory. In order to "start from scratch" and resync your remotes, you'll want to do the following:
    1) Turn the Wii off and unplug it for at least 1-2 minutes. After this time has elapsed, plug the Wii back in.
    2) Turn the power on again, and press the "Sync" button on the front of your Wii console for 15 seconds when the "Health and Safety" screen is being displayed. This will clear all previously synced devices from the Wii's memory.
    3) To sync a remote/accessory to the Wii, you'll need to press the small red button located just beneath the batteries. When you do so, the blue lights on the front of the remote/accessory should blink.
    4) Next, quickly press the "Sync" button on the Wii console again.
    5) After the "Player" LED light stops blinking and stays lit, the remote/accessory is synced and no further actions are necessary with that remote.
    6) Repeat steps 3, 4 and 5 for each remote/accessory you wish to sync to your Wii.
    Should following these steps not resolve the problem, I'd strongly suggest checking out Nintendo's Wii remote troubleshooting website for more information.
    http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    Jul 23, 2008 | Video Game Consoles & Games
    Nintendo Wii Fit for Wii Logo
    149 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
