Question about Kenmore Washing Machines
Why can't i get my kenmore model 417.44082400 into diagnostic mod
I have the washer tech data sheet from my washer with steps to get the washer into diagnostic mode. I follow the steps for a diagnostic test but it does not work. Any ideas?
  • CONNIE BLAMER Mar 01, 2009
    Additional info: does the machine need to be empty of clothes to perform the diagnostic tests? The problem is that I have to replace my Door Lock/Switch Assy but have no $ for it right now. What I'm hoping to be able to do is run a spin in diagnostic mode so that I don't have sopping wet clothes at the end of the wash cycle until I can afford the part.
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My kenmore elite front load washer model # 110.46742702 displays code F 27. what does this mean?
"F27" is an Overflow Detect error code. The following link explains the code in detail and lists the steps to take to try to resolve:
http://www.fixya.com/support/r3608602-f27_error_code
A simple thing to try before assuming you have a component failure is to UNPLUG the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). In some situations these error codes can be erroneous and a simple CCU reset will correct the problem. If the error reappears following a CCU reset, then you have a legitimate problem that you will need to troubleshoot to resolve.
NOTE: Each one of these washers come with a technical data sheet enclosed inside the equipment cabinet. The tech sheet lists all error code definitions, diagnostic procedures, troubleshooting data and wiring diagrams. You may have to refer to the tech sheet to assist in troubleshooting this problem.
The tech sheet is located behind the lower toe panel directly below the washer door. To access, locate and remove the screws under the bottom front edge of the panel. For better access to the screws, you can prop the two front feet of the washer up with a 2x4. With the screws removed, the panel should drop down, then come off. The tech sheet will either be located directly behind the toe panel or affixed to one of the interior cabinet walls.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
Wiring Diagram for connecting ccu
If you are referring to a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and WIRING DIAGRAMS.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Oct 21, 2010 | Washing Machines
My Kenmore HE3t was run for more than 10 minutes with water valves turned off. Now it will not reset. How do I reset the machine?
UNPLUG the washer for at least 30 minutes. This will reset the Central Control Unit (CCU), which is the main control board for the washer. Make sure the water valves are on and plug the washer back in. If the washer still does not clear after a CCU reset, there is a diagnostic procedure you can run that, not only checks all the basic washer functions, but will also clear most momentary program glitches. Each one of these washers comes with a tech sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Aug 23, 2010 | Kenmore HE3T Washer
Kenmore washer elite 44832200, error code h and f
The error codes aren't listed in the owner's manual.
Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information and let me know if you need assistance beyond what the tech sheet provides. I hope you find this information helpful.
May 09, 2010 | Kenmore Elite 45986 Front Load Washer
Repair manual
Actually each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
May 04, 2010 | Kenmore Elite 45986 Front Load Washer
How do I put a Kenmore 417.44092500 into test mode
Each one of these washers comes with a technical datra sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. Some model washers have two versions of diagnostics that include SHORT and LONG step modes to include simple and more advanced troubleshooting procedures. Since the procedures for entering diagnostics differs between models, it is recommended that you refer to this tech sheet to ensure you perform the procedures correctly.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Apr 07, 2010 | Kenmore Energy Star 44092 Front Load...
Kenmore elite he3 model#110.42822201 washer; where can I get a schematic? Graham
Every one of these front loaders come with a technical data sheet inside. You need to remove the lower toe panel directly below the door to access it. The screws are located under the bottom front edge of the washer. You may have to prop the two front feet of the washer up to access them (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off. The tech sheet will either be located directly behind the panel, or affixed to one of the interior cabinet walls in an envelope. The tech sheet includes all troubleshooting data, error code definitions, diagnostics procedures, test points and wiring diagrams. I hope this helps you.
Jan 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer manual
If you are looking for an Owner's Manual, go to managemyhome.com and type in your model number in the following format: "110.28032700" under the "Manuals" link. Your owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
If you need technical data sheet to troubleshoot a problem, the washer comes with a tech sheet inside the cabinet. It is located between the wash tub and cabinet in the front of the washer. The tech sheet includes all diagnostics procedures, fault codes and technical data to troubleshoot any problems you may encounter.
You can access it by lifting the washer top, or by reaching up from the bottom of the washer. If you choose to open the washer top, you need to locate the two retaining clips along the front of the washer in the seam where the top panel meets the front of the washer. Push in on the retaining clips and the top panel will pop free and can be lifted up. Make sure you hold the lid closed while lifting, so that it does not fly open when lifting the top. I recommend taping it closed.
If the tech sheet is missing, you can order a new one. The part number is W10026628.
If you have questions, please let me know. I hope this helps you.
Oct 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
250 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
