Question about General Electric WHDSR316G Top Load Washer
Loud draining my ge washer mod WHDSR316G1WW is less than a year old and works fine with one exception when it drains it is very loud
    Sergeant:
    Champion:
  • 205 Answers
Hello mam please clean the drain filter and check the noise if you feel the same then please change the drain pump.
Posted on Sep 22, 2009
  • anantha reddy
    anantha reddy Sep 23, 2009
    hello mam
    have you done this what is the result
Banging noise comming from back of washer near the belt
I have a GE WHDSR316G1WW top loading washer and the drain hose located on the upper left rear of the plastic outer tub came loose. It sounded like a worn seal or bearing because it was banging so loud. I removed the control panel, top panel and front panel, reattached the drain hose into the housing hole and the problem was solved. Saved $80 service call.
Aug 15, 2013 | Kenmore 24032\24036 Top Load Washer
Cannot get drive belt on ge washer model #whdsr316g1ww
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
Feb 25, 2010 | Washing Machines
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Washer squeaks really loud while agitating. Drains great 6yr old
Could indeed be the belt or at worst it could be thr main bearing getting dry and gradually seizing up. Hope it,s the belt!!
May 20, 2009 | Washing Machines
hi, reset the printer.
open th right door,without paper then close the door
it work
thank you
May 17, 2009 | General Electric WHDSR316G Top Load Washer
GE washing maching model #whdsr316g1ww
sphion effect,,you drain hose is to low,,pick drtain hose up at least height of unit before,,it can go down,,,onthejob
Jan 08, 2009 | General Electric WHDSR316G Top Load Washer
GE washer WHSR2070VWB about 9 years old does not spin dry clothes. All of the cycle works except the final expulsion of water
If the cycle stops when it is supposed toi drain , that means that there is a problem with the drain pump.
Oct 12, 2008 | GE Washing Machines
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
General Electric WHDSR316G Top Load Washer Logo
141 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
