Question about Microsoft Premium System for Xbox 360
Can.t connect to the internet using a wired connection..
  • 4 Answers
If you're just pulling the ethernet cable off of the back of your computer, it won't work. You'll need a router connected to your network first, and then connect the 360 to the router with a second ethernet cable after setting up the router.
step by step.
1. connect the ethernet from the modem to the router.
2. connect the small ethernet that came with the router to the PC.
3. insert the cd that came with the router and follow the setup.
4. plug the 360 into the router with an ethernet cable into an empty port.
5. enjoy.
If you have a router already, you may just want to check the ethernet cable for any breaks. easy way of telling if it's the cable is to simply use a different cable, or use the cable for a different device, like your computer. change the cable out with a good one and see if you can still get online. If so, then your cable's not the issue.
If you have a router, good cables, and it's still not working, you may need to have the 360 looked at by a licensed repair service, because the ethernet jack on your 360 may have went out. This is rare, but it's possible.
Posted on Mar 01, 2009
I have a Sony bluray with built-in WiFi and I show I have internet connection, but when I try to watch Netflix I get a message stating not connected and invalid information and data. Is there a step or...
Are you using wifi connection, or hard wire? If you are using wireless, there is a possibility that, while you can connect to the router, the router it's self is not connected to the internet. Please check if your router has internet access, then, if you are using wifi, I would suggest hard wiring directly to your isp's modem using a "cat5" or Ethernet wire. Less lag streaming movies, and while playing games. And wired connection will always be faster than wifi.
Jul 02, 2014 | Video Game Consoles & Games
I have wireless Internet! I have a laptop, I tried to connect to it~ It will connect to the router, but won't connect to the Internet! Help!
How many wired and wireless computers do you have ion the network.
Do you have any wired computer ?
Connect your laptop to the router with the Ethernet cable and try to access Internet. See if the wired connection is working or not.
If the wired connection is working then I think you will need to check the wireless settings of the router and the laptop.
Try following websites
Router setup
How to connect to the wireless network
May 15, 2012 | Computers & Internet
Internet connection setting is on wired and i need to change it to wifi
I believe this website can answer your problem.
Note: You need either an "Xbox 360 S" console with built-in WiFi or an "Xbox 360 Wireless Networking Adapter" to have a WiFi internet connection. If you can use a wired internet connection, you should use it because a wired internet connection connects faster than a wireless internet connection.
May 31, 2011 | Video Game Consoles & Games
I can't connect to the Internet, wireless or wired. I want to put netflix on their but how?
In order for Netflix to work, you must have an active internet connection. You can connect to the internet on your Wii wireless or wired using a USB/ethernet adaptor.
If you don't have an internet connection, you can't use Netflix.
Mar 25, 2011 | Nintendo Wii Console
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Interner connection
well first is it wired or wireless?
Wired: just plug in your Ethernet Cable in the back of the PS3 and go to Network Settings, Internet Connection and pick wired. do a Connection test and your good to go.
Wireless Network Settings, internet Connection then pick wireless, pick our access point and put any security codes in(WEP, WPA-SK) connection test and it should work.
But i recommend using the Wired connection cause the internet is a lot faster.
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Premium System  for Xbox 360 Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
