Question about Kenmore 73952 Gas Dryer
Dryer stops working after 10 minutes
My 70 series Kenmore electric dryer for some reason stops after about 10 minutes. I normally use the timed dry but I've also tried the more dry ... less dry feature and it does the same thing. What is the problem?
  • 163 Answers
Motor may be over heating.may need new motor.
Posted on Mar 06, 2009
2 Suggested Answers
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
Kenmore 70 series dryer 110.96573220 only heats on time dry and delicate, not on normal
I would check the temp switch located in the console panel, sounds lile maybe the contact is burned since you have heat on delicate and timeddry.
Feb 02, 2013 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore 70 Series
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 73952 Gas Dryer Logo
315 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
