Question about Motion Computing LE1600 Tablet PC
Have motion tablet pc 1600 , suddenly when starting up get "problem or unable to load operating system"
  • Anonymous Apr 06, 2009
    my problem with my tablet is that the pin dose not work after i install the motion computing software? OR if t dose work it will only work second are two, then the pin wont work. i have also seen that in others that i work on they are good only untile i re-start.
    please and thank you
  • 3 Answers
It could be one of several problems:
1. Bad hard drive (reasonable likely depending on age); does the hard drive make noise or spin?
2. Loose hard drive cable (less likely)
3. Virus (likely)
If it doesn't boot at all you can open up the back and make sure the hard drive is "seated" properly - that means all the connections are firmly in place. If that doesn't take care of it you will have to try and reinstall the OS.
John Hill
www.alltp.com
www.tabletpcbuzz.com
Posted on Mar 04, 2009
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
Motion m1400 tablet pc reset bios
My m1400 Can't find operating system and I can't install another xp. It wont boot from my usb cd rom drive, What are my options?
Apr 14, 2011 | Motion Computing M1400 Tablet PC
I need a system restore disk on my Gateway Motion Computing M1200 Tablet. Help!
Hey nick, have you tried to buy one from motion customer care, I bought one for around $20
Jan 25, 2011 | Gateway M1200-3004265 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Installation
istall the drivers manually , it will work again
May 21, 2010 | Motion Computing LE1600 Tablet PC
Hi .I am trying to Install WIN 7 on LE1600 from the USB (Enabled with Bootable Win7).I am able to boot from the USB but stucking at giving the Inputs for Regional seting at Installtion as the KEYBoard is...
As far as I am aware windows 7 has not been confirmed for tablets or win CE platform type devices
Check you manuals and any Cd's that came with the 1600 and see if there is some form of reset or original system restore ability.
Microsoft has a win7 compatibility check utility anyone wishing to try win 7 on these types of device is recommended to use that first to identify potential issues.
Sep 11, 2009 | Motion Computing LE1600 Tablet PC
Install new os on motion le 1600
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
Mar 30, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Tabletpc
you cant free download operating system from the web
May 06, 2008 | Motion Computing M1400 CENTRINO 1.1G 512...
Need touchscreen drivers for Gateway M1200. Hi there I recently bougth a Gateway M 1200 Tablet PC. Unfortunatly I did not get any operating system or drivers and has not been able to use my touchscreen. ...
I just bought one of these used, It had a fresh intall of windows XP tablet. When I got it the touch screen would not work. I have tried dowloading the drivers. I download Motion dashboard for this model. When I open it is says" Dashboard can not be run on this computer" I dont know what to do??
Dec 17, 2006 | Gateway M1200-3004265 Tablet PC
Motion Computing LE1600 Tablet PC Logo
443 people viewed this question
Top Motion Computing Tablets & eReaders Experts
jason
Chris Larocque
dante
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
