FixYa.com
Tags:
Sea and Sea Sea King Snapper 35mm Point and Shoot Camera
Can I use NiMH batteries instead of NiCads in my...
By LiZzIe - usenet poster
The manual for my Vivitar 285HV says you can use NiCad batteries but says
nothing about NiMh's. Anyone know if it is safe to use rechargeable NiMh
batteries in this unit?
Thanks in advance!
-Paul
replace nospam.nospam with att.net to reply privately.
Help prevent pet overpopulation. Please spay & neuter your pets.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Grant
Grant - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Perhaps!!!
Check with with Vivitar to play safe.
NiMh cells outgas more then NiCd cells. Old flashes may not be
ventilated adequately for NiMh cells and like some Sea and Sea flashes
they might explode when using the NiMh cell.
Better safe then sorry and safe just means you sak Vivitar in CA.
HP Marketing Corp.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
There is a brief moment in a person's life where experience has taught it's
lessons, and just before alzheimers takes what time has given. Don't assume
that someone giving advise is outside the bubble, just because you are.
Solution #3
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Interesting enough, that faster charge, can be a problem. I doubt is
many modern units will have any problem, but may old units would. The
faster charge capability can cause overheating of the capacitors and if
repeated flashes are used the flash tube may also overheat.
Back when NiCads came in this was a serious problem.
Joseph E. Meehan
26 + 6 = 1 It's Irish Math
Solution #4
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
Do keep in mind that NiMH batteries self-discharge much faster than NiCads (in
the order of weeks instead of months) so double check them if you haven't used
the flash in ages! It's their only downpoint when compared with NiCads and a
minor one at that.
Solution #5
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
Far as I know there is no problem
home of The Camera-ist's Manifesto
The Improved Links Pages are at
Solution #6
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Not only safe, but preferable and recommended.
NiMh batteries do not have to be discharged before recharging as NiCads do.
They can be charged at any time.
Also... They will actually charge your flash faster than alkalines.
Can you Help with these Film Cameras problems?
Film Cameras
Nikon F3 rewind knob
I need a rewind knob and crank... Answer This...
Film Cameras
Minolta Dynax 500si displays...
My European model Minolta Dynax... Answer This...
Film Cameras
vivitar 4000S model
after clicking the camera does... Answer This...
Film Cameras
Minolta X-300s film loading...
Hi, This camera was in storage... Answer This...
Film Cameras
lomo super sampler problems
Hi I saw you answered a similar... Answer This...
Repair Service
Find Film Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
