Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice crusher has stopped crushing
I can get ice cubes but my ice crusher has stopped working.
i can toggle from cubes to crush and vice versa and the lights work but i do not get any crused ice.
what can i do to fix it? GE side by side Profile TPS24PPBABS. Ice dispenser works in cube mode but not in crushed mode. The light comes on when I push the button but the auger doesn't turn. I checked the solenoid, it works fine and the bar from the ice dispense is correctly positioned within the acutator. In the crush mode the motor doesn't even hum, so it's not jammed or anything. Any suggestions?
  • GE Master
  • 3,361 Answers
Replace the switch behind the front panel on the freezer.
Posted on Mar 09, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Why is my icemaker not chopping/Crushing Ice
If there are blades involved then they might be bent and/or need sharpening.
Jun 01, 2015 | Refrigerators
Ice crusher stuck on crush
your ice solenoid is frozen. It is located behind the ice bucket next to the auger motor. It will need to be removed, unfrozen, and squirt a little wd40 to prevent it from happening again
Mar 19, 2014 | Frigidaire FRS26H5AS Side by Side...
Ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Feb 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker only makes crushed ice, no cubes
The button which selects cubes versus crushed controls a solenoid which engages/disengages the crusher. If the mechanisms which crush and push the ice from the chute are all clean, free of ice, etc., then the solenoid is not working. It either has loose/dirty connections or the solelnoid is bad.
May 05, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Crushed ice only.No cubes.
Pull the ice bin out about 4 inches and re-insert it in the slot in the rear to reset the crusher arm.
Mar 11, 2009 | Whirlpool GD2SHGX Refrigerator
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
The crusher function on ice making part of my Maytag Zigzag fridge freezer is not working. I have ice cubes but no crushed ice
pull the bucket and check the solenoid on the back wall this is what shifts the bucket to crushed and cubed
Jul 31, 2008 | Maytag Refrigerators
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Jan 13, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
955 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
