Question about Canon PIXMA iP4300 InkJet Photo Printer
Service error 6A00
I had a paper jam and removed the paper including a tiny bit left in the printer but it still won't print telling me I hae a service error 6A00. I can't find this in my manual. Can you help please? Thanks Lynne
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Won't Copy. error code 6A00.
A600 error
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you
Jan 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
ERROR CODE 6A00
A600 error
Jan 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6a00 I don't see any paper jammed anywhere was printing fine help
Hi
1. Please removed cartridges.
2. Now slid craddle to the far left.
3. Check if there are any tiny piece of paper etc...... remove them.
4. Now put back together, plug in, and error code should not show up again.
Aug 06, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Had a paper jam, corrected this made sure ther were no bits. Got error code 6A00 dont know how to get printer working again. tried unplugging, resetting.
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
May 06, 2010 | Canon MP610 Photo All-In-One Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00 what is it how do you fix it? this is what is displayed on the printer. I had a paperjam last night. I removed the paper and it worked ok. This morning it displayed this error message and...
6A00 is AP position error.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Had paper jam. Now PIXMA IP5000 shows service error 6A00 and light alternates between green and orange 12 times. Have tried unplugging, turning off,etc.
Print head might be stuck. Try opening the lid and sliding the cartridge tray over to the left. Check to make sure there is no piece of paper left jamming it. While you are at it, clean the base pad by dabbing with a piece of paper towel to remove excess ink. You may also want to remove the Print head itself and then reattach. Make sure there is no gunk buildup. Hope this helps.
Sep 07, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
240 people viewed this question
old marine
old marine
