Question about Eljer TITAN 15" Two-Piece Toilet - 091-0755/Choose Color=Ru
Water line stain
I have a new eljer titan toilet that has developed a waterline stain. How do I get rid it without damaging the finish?
  • grgnixon Mar 01, 2009
    Thank you, I will buy it and give it a try.
    Guru:
  • 166 Answers
This always works for me! How to easy clean your nasty toilet ring
Posted on Jun 14, 2015
Try a product called Iron Out. You can use it for a lot of different types of stains that build up in toilets, dishwashers, washing machines, etc. You can get it at any hardware store. I'm in PA, though, so I don't know if it's available in all states. This worked for me, but the minerals in your water may be different than mine and it may not work the same for you. Good luck!
Posted on Mar 01, 2009
Flush shoots out of the toilet
Sounds like you have a blockage. Plunge the toilet until it flushes correctly.
Dec 21, 2013 | Eljer TITAN 15" Two-Piece Toilet - 09
Occasionally after flushing ,water continues to trickle slightly in toilet bowl. Have changed flapper twice. Wondering if the seat that the flapper sits on is worn or something. It looks ok. Have a one...
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Feb 27, 2011 | Eljer Toilet Onepiece Canterbury ...
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 14, 2010 | Eljer Toilet Seat Tosca 124200000
Toilet is leaking between tank and seat. the water that is collecting on the back of the toilet is blue. what does that mean.
Check for any loose connections or a crack in the pump casing. Check all the rubber fittings also for any holes or cracks.
Oct 11, 2010 | Eljer TITAN 15" Two-Piece Toilet -...
The refill water in the toilet bowl is low ever since installation. How can I add more water?
Most toilets use less bowl water. But to check yours, be sure that the little plastic refill hose goes down the overflow tube.
Sep 14, 2010 | Eljer & Titan Elongated Toilet Bowl
Tank is not filling to water line
Turn clcokwise to rasie water level, don't mess with the weights unless adjusting the screw to get water to proper height does not do the trick.
Jul 04, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Toilet tank replacement
I believe you will find it cheaper to replace the whole toilet. good luck
Jan 24, 2009 | Eljer TITAN 15" Two-Piece Toilet -...
Eljer TITAN 15" Two-Piece Toilet  - 091-0755/Choose Color=Ru Logo
352 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
