Question about Cyberhome DVD Recorder - DVR1600
Help setting up tv to dvdr/cablebox
Can u help me set up my tv to my dvdr and cable box? ive had it once b4 all by my self but i dont rememebr what i did lol i am having troulbe setting up the DVR to receive the Cable tv to copy/record the programs i have recorded on the V+ cable box when we had the Sky + bos we used to tune the tv to channel 19 but noe for some reason that doesnt work now we have swpped over to cable tv? does anyone seem t know how to sort this problem out?
  • 75 Answers
To complicated to post call 2095683327 for possible help.
Posted on Apr 02, 2009
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
My polaroid tv remote isnt working
Get a new remote or try it again with new batteries.
Aug 17, 2017 | Polaroid 1720-7 Remote Control
Codes and how to set box
1stly.......press.............menu............then.............yellow button on ur remote..........it should pop up?? unless you got old box its bluebutton........then use ur remote to enter codes such as(letter A would be TV)it tells you at bottom of screen if your following these steps..........then 1st two boxes at top...............enter...............5A 01 if ur telewest.........then codes
key 00 = 98 B0 BA 52 D3 21 08 B4
KEY 01= D2 EA 29 B7 B5 52 E9 AD
then press................OK...............and then..............EXIT that should be you sorted always use remote to enter codes........recall..........info.............p+.............p-.....them buttons u should see at bottom screen??
hope helps?/
charlize
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
Nov 09, 2008 | Bose 3 2 1 GSX System
Audio from tv
It sounds like you have the red,white rca cables hooked from the back of the tv to the red,white input on the stereo or the same connection from you hd sat box or hd cablebox. In order to get the same sound quality from tv service as you do on dvd is to run a fiber optic cable or digital coax audio cable from you hd sat box or hd cablebox to your stereo which means no red,white rca cables at all, take them out. Also once you do that you must be on a hd channel to get equal sound quality of a dvd movie. I know on some hd cable or hd sat boxes you have to go in and set them up to dolby digital as well after you hook it up the way I was explaining. Try this and I hope this is helpful.
Nov 09, 2008 | Koss KS4192 System
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Hook up to tv
You need a device like a VCR or receiver that has Composite A/V inputs, and can convert the signal to what your TV requires (coaxial right?).
If you have a VCR or Digital Cable Box with A/V inputs, you can connect it to either of these devices and set them to A/V Input. Set the Insignia player to A/V Out by pressing the SOURCE button until it displays A/V OUT on the player screen.
You should be good to go.
Oct 31, 2007 | Insignia IS-PDVD10 Portable DVD Player
Cyberhome DVD Recorder - DVR1600 Logo
97 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
