Question about Avanti WCR5103SS Stainless Steel Wine Cooler
Loud compressor of my Avanti Wine Cooler
My Avanti wine cooler is very loud and sounds like a diesel engine. It still cools perfectly. Any thoughts?
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Posted on Jun 05, 2009
SOURCE: Noisy Wine Fridge
I had the same problem, and found it to be as RonLew described. In our case it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Posted on Jun 13, 2009
SOURCE: Avanti Wine cooler Model #
I had this issue and it had all to do with ventilation. If the fridge is in too tight of a space without any type of air space this will be the result. I was able to cut into the cabinet behind the fridge and put a 18" x 18" grate that allowed air to move. Problem solved!
Posted on Jul 22, 2009
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
My Avanit WC54 wine cooler turns on, however it does not cool. Every few minutes it makes a clicking sound
if you are handy go to a refrigeration supply hoese and buy a 3-1 pack remove the wires from the compressor let it cool if hot and hook to 120 volts wiring it shows you on the package..........luck
Jun 16, 2011 | Avanti WC54 Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Avanti WCR5103SS Stainless Steel Wine Cooler Logo
66 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
