Question about Marantz SR-7200 Receiver
I have a Russound CAV6.6 Rnet controller. The controller will turn on, but I can get any sound out of the speakers. It used to work just fine. Now the lights come on, but no sound from the speakers. I took the cover off and found 2 fuses, but they didn't look like they were blown. I can't figure out how to fix problem?
  • billyboy5645 Apr 19, 2009
    Same problem. Did you resolve? If so, please let me know. Thanks.
Have you changed any connections behind the CAV recently? This happened to an associate of mine once and it just turned out to be something simple. This may or may not be the situation in your case. Check to make sure your source audio cables are connected to the correct source number that you assigned in the programming (Ex. AM/FM Tuner = Source 1). Also make sure your audio cable is connected to Source 1 IN (and not the "OUT").
Narrow down the source of the problem:
Make sure the keypad you are using to test the CAV is not in "Mute" mode. Press the "Pause" button to engage/disengage from mute.
To further troubleshoot your issue if the above is not the case you want to use a device (such as an ipod tthat you are sure the audio output is working using a stereo mini to red and white rca cable) and plug into each source input (one at a time) behind the Cav then monitor that source# on the keypad to see if you hear the ipod on any of the sources. If you hear the ipod playing on some sources and not others it obviously means some of your source inputs are having problems and the unit needs to be shipped to Russound for repair.
Make sure the front of the Cav6.6 has the proper colored lights lit up. When no keypads are on the zone should show red, when a keypad is off the color should be green for that zone, if there is a short circuit with the speaker wire the CAV might be in protection mode and the color might show orange.
Hope this helps.
Posted on Mar 23, 2009
  • jeffsaxonis Mar 23, 2009
    I need to correct myself on my last post. I got distracted and misinformed you on the lights on the front of the CAV. When a Zone is ON the zone color is GREEN (Makes sense). When the zone is off it's red. Orange may indicate a speaker wire short and the CAV is in protection mode in which case make sure the copper from each speaker wire are not touching each other and shorting out.
Did you find the answer to this problem? I have the same issue.
Thanks
Posted on Feb 10, 2011
The first thing you need to do is test the speakers....Anyone who says anything else is obviously not a professional and should not be responding. After checking the speakers you need to take a voltage meter and make sure you are getting voltage on the speaker output. This should let you know exactly what is causing the problem in about 10-15 minutes.
Posted on Jul 15, 2010
Russound CA6.4 amp / controller - 3 of the 6 zones can't switch source inputs.
I suspect the inputs will all go into an IC. You just need to trace one of them back till you come across it. Either the circuit around it will be the problem, or more likely the IC itself.
Jul 01, 2014 | Russound CA64IL Amplifier
Onkyno receiver shuts off
The system is overheating
Jul 27, 2008 | Onkyo TX-SR605 Receiver
Russound ca4-kt1 no sound
Does the system have its own speakers? I understood that sound system required speakers to be attached. Check that you put the right model up.
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Mar 31, 2014 | Audio Players & Recorders
Replace the TCH-1
I am having the same issue. Did you receive any more information since January?
Jan 22, 2014 | Russound Rnet Touchpoint White -
I have a russound tch1 and since the ios 7 upgrade its not working.
Just saw this on fixya - if you still have the system I would recommend going to Russound.com Support under integration to download the updated firmware for the TCH1 or look into the new perkins innovation unit that supports the new My Russound App
Oct 19, 2013 | Russound Computers & Internet
When it says 'no controller' on CAM6.6T what do i need to do to fix it?
Have you called the installer that put the system in? No Controller means exactly what it says: the keypad powered up and it doesn't see the controller (CAM6.6). This can be caused by a short or break in the Blue pair of the CAT5, the punch down on the back of the keypad or the RJ45 connected to the port on the back of the CAM is loose. Should be easy to troubleshoot for someone familiar with the installation of the system.
Mar 31, 2013 | Russound Cam6.6t 6 Zone 6 Source...
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
I have no output on my Russound ca6.4. All lights on console and room controllers appear to function. Input double checked. Could amp be fried?
CA6.4 that has no sound, but all other funtcions are fine, has a problem with protection IC 10 (uPC12370). Check the Cap C28 (2.2uF/50V). If you read any AC
Volatge on that Cap, it means Cap is dry. Replace it with 4.7uF/50V and go back to
your regular duties.
P.S. Since the unit is discontinued, I would love to see basic diagram, available from the manufacturer for download, for easy troubleshooting. I had to spend feew precious minutes to fix that.
May 17, 2011 | Russound CA64IL Amplifier
I wish to control volume on 4 pairs of speaks at 4 different locations please
What you will need is an autoformer based speaker selector with volume control for 4 speaker pairs. This will take the left and right speaker wire out from your amplifier and distribute it to 4 pairs of speakers. Each pair of speakers gets it own volume control so you can control each room sound independently. It will also do speaker impedance matching so that your amplifier is not being over driven by the 4 pairs of speakers. The manual for the product you purchase will aid you in the proper settings of the auto former control. You can find this product from companies like Russound or Niles.
Aug 21, 2009 | Audio Players & Recorders
My SR605 gets extremely hot. This is especially true when both amplifiers are running together supporting 2 separate channels. I added a 2 way speaker selector from Russound that supports 2 sets of 8 ohm speakers on Zone 2 and the receiver shuts down at about 74 dcbs and gets very hot. Checked the jumpers on the selector and they are set at 8ohms.
Have returned the Russound selector to them and had it checked out. Appears to be fine. Even when Zone 2 is not in use the receiver gets extremely hot. It is in a wood cabinet wih glass doors but even with the door open the temperture is very hot. As the volume is raise the heat increases and the receive trips off.
Very unusual in my opinion. Is this normel for the receiver to heat up as the volume is increased.
Jun 22, 2008 | Onkyo TX-SR605 Receiver
Marantz SR-7200 Receiver Logo
1,329 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
