Question about Kenmore 44042 Front Load Washer
Kenmore 417 starts then stops when water doesnt come out.
Started out with a little leak. washed the detergent drawer and a magnet fell out. dont know where that goes. washer starts and doesnt start. door locks fine, clicks then the water supposed to come out and doesnt. then single beeps after beeb after beep. i tilted the machine on its side so i can remove the bottom to find the leak. did that do something to it? i dont know. i performed the diagnostic test five lights plust the start lit up once. then the start blinked 3 times. is that the reed switch. where is that any way. need help.
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Kenmore 417 washing machine lock won't engage so it won't start.
the door latch is a normal electrical switch,
open the cover, and brridge it and try, maybe it needs adjustment or you didn't fix the wires plug
Oct 21, 2014 | Kenmore Washing Machines
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
The washer won't fill because the magnet fell out from the detergent drawer after being removed for cleaning. Where does the magnet go?
On the right side - halfway down the try - you'll see the witness marks.
Jun 25, 2009 | Kenmore Washing Machines
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Magnet fell out of dispensing drawer and I don't seem to be able to find where to replace it. Washer will not start without it. Kenmore model 417 44152400
I dont see why there would be a magnet in the dispenser draw in the first place,,,, is it possible it somehow got in there by accident and when it fell out you thought it belonged in there ?
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Detergent drawer will not close and washer will not run.
pull draw out on right hand side fron you will see a little square recess,,,there a sensor on the in side of the main control,,if you cant seem to place take another magnet and place it on the side of control..and thats where to put the magnet
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 44042 Front Load Washer Logo
122 people viewed this question
Sal De
 Brian Main
Brian Main
