Question about Canon imageRUNNER 8500 Copier
My copier not working only display the eroor code 602 please help me...
  • Canon Expert
  • 1,326 Answers
The error code E0602 means that the Hard Drive is not booting up correctly. There are a few things you can try, but most of them are only a temp. fix. Mostly you will have to replace the hard drive in the copier. Wish I had a better Solution for you
Posted on Mar 02, 2009
I have problem in my sharp AR- M205 Copier When i Swith On Of the Printer Then H 2 eroor on the display
H2 Trouble code is a problem with one of your thermistor. I would start by removing the fuser and then check if your thermistors are damaged or need to be cleaned. After you clean or replace use Simulation 14 to cancel the error. Perform the following procedure to enter the simulation mode. "#" key Interrupt key "C" key Interrupt key
"14" Main code Start key
Jul 14, 2014 | Sharp AR-M205 Copier
Tip
Xerox machine ir 3320, error 602-003 and 602-004\r\n
The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this, hold on 1 and 9 (from the machine key board) then switch on the copier; then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
on Nov 02, 2010 | Office Equipment & Supplies
Eroor code on Sharp ARC260M copier
Please report the error code e.g., F1-47, C1-30, H5-01 and so on.
Jun 16, 2013 | Sharp Office Equipment & Supplies
I have a xerox machine ir 3320 i have facing a error 602-003 and 602-004\r\n and printing are coming zigzag type
try this,
then wait arround 1 hour all sceer will be white then the copier will display download mode.
Oct 31, 2010 | Canon Office Equipment & Supplies
I am babykaruna from india. i have ir3300 copier machine and in that 1 month ago i got error code 602-003. So I came to know that is an hard disk error. So I replaced new disk and after that my machine...
hi karuna,what you can do is....press * 2 8 *,copier,function,system and HDD clear,ok......ann wait untill the process drop to 0% and switch off your machine,after 5 second on it back,thanks
Jul 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
The display sceen is blank & you see the number on the bottom of the display? Your hard drive has crashed... You will mostly need to have the hard drive replaced to solve this problem.... Good Luck
Jun 04, 2010 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 8500 Copier Logo
163 people viewed this question
old marine
old marine
