Question about U-Line 15R Compact Refrigerator
Honeywell compact fridge not cooling
I have a Honeywell compact fridge(no freezer) and it has stopped cooling.
I have called Honeywell and they said turn the unit off and it resets itself.
Tried this 3 times still not working. Called Honeywell again and they started the song and dance about receipt,it is great technology and this should not be happening etc,etc. I have sent the receipt about 6 months ago but still no refund. Can I repair it myself? Fans chatter,no cooling.
  • 478 Answers
Yes, listen to regular fridge for the sound of the compressor. do you hear it now? does it fill warm? Do you hear a clicking noise? Ifso, you'll need a potntial start relay, or a 3 in 1 start kit 15.00
Posted on Mar 12, 2009
2 Suggested Answers
SOURCE: Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Posted on Jun 04, 2010
Ro@hotmail.comtemp fridg& frezer will chang 30 to 40 degrees if you open either door it will take a long time for for temp to drop
The compressor is the part which cools the refrigerator.---------- First i will explain the working procedure of your sanyo refrigerator.---------- In the refrigerator, there is a part called compressor, the compressor is the part which cools the freezer section, When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold.--------- So the freezer section cooling/ freezing is must.If freezer is not getting properly cooled or not getting cooled, then fridge section will show the low or no cooling problem.--------------
In your refrigerator, its quite possible that compressor is got weak, nor complete faulty but little bit weak.So when you open and close the fridge or freezer door , the compressor is not that strong to maintain the required temperature.So its working hard to cool inside temperature, but its not doing it quickly as it should.---------.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- ----------------
There is manual reset procedure, sometimes the ice gets frosted all over and blocks the ventilation's for cool air to pass from one section to another, and this also causes problem.So directly going for compressor inspection, before that you can try manual reset procedure and see if that helps.---------
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked. -------- This should help. Thanks.Helpmech.
Aug 22, 2011 | Sanyo SR-3620 Compact Refrigerator
Fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgsjkysk
Sep 24, 2010 | Sharper Image (SI714SL2) Compact...
Our fridge is not give the cooling
heatman101
Jul 16, 2010 | Goldstar GR131CN Compact Refrigerator
Mar 18, 2010 | Refrigerators
My compact fridge does not defrost and ice builds up in freezer section. How can I disconnect the freezer and not use it?
Lynne, the freezer section is what provides the cooling for the fridge, so there is no way to disconnect the freezer and still be able to have the fridge operate.
With the small compact fridges, the only thing you can do is to manually defrost the unit, when the ice buildup gets too much, which can vary, based on how you use your fridge, how often it gets opened and closed, etc.
Some compact fridge models have a small push button in the center of the temperature setting control knob - if your's has one, you can push that to initiate a self defrost cycle. However, you'll need to have some towels handy to collect the water that will result from melting off the freezer section.
There are not many small, compact fridge units that have the no-frost feature of full sized fridges, as it is more costly to build in all the needed components required to have frost-free operation. Not to mention the size of the fridge gets much larger, because of all the space needed to house those features (defrost heaters, electronic controls, ciruculating fans, control vents, sensors, drip/drain pan, etc., etc.)
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | GE Refrigerators
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
Sep 28, 2008 | Kenmore Stainless Steel Compact...
U-Line 15R Compact Refrigerator Logo
400 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
