Question about Dell OptiPlex GX260 PC Desktop
I have decided to replace my network card on my optiplex gx260, due to yellow ? & inability to connect to the internet. went through all the driver search business without sucess. opening the box, I don't see a card directly behind the ethernet port. where is it at? Clay
  • 447 Answers
The ethernet port is integrated on your unit. You should just have to install the new card (and drivers) and plug it in. You can however go into the device manager and disable the onboard if you wish but it shouldn't be necessary.
Posted on Mar 01, 2009
My dell Optiplex GX-620 But my lan indicator was always green flashing but now Its red all the time. please give me th sol
Red would be no signal.
1. Check network cable (try a different cable).
2. What is connected at the other end? Hub? Switch? Modem? Does the other equipment also have lights?
3. Check the settings in the operating system / driver. Select "Auto" for link type and speed. Use manufacturers defaults if possible.
4. Uninstall the network card driver, reboot, re-install the network card driver
Jan 13, 2011 | Dell OptiPlex GX260 PC Desktop
My lan drivers disappeared after formatting optiplex GX260. What do i do?
You'll need to access Dell's Drivers and Downloads page from another computer that has internet access, and supply the Service Tag (or other method of choice) information to obtain a list of drivers for your GX260. Assuming you're using the original LAN card, you'll have to download and install the required driver to restore network functionality from the Dell site (if other than a GX260 LAN card, you'll have to go to the LAN card manufacturer's site for drivers).
There may be more than one LAN driver from which to choose. If unsure which version you have - you'll need to get all of them and install them one at a time until you find the one needed by your machine.
Please rate this reply if it was helpful to you - good luck!
Jun 21, 2010 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 ethernet driver troubleshooting. I installed the network driver for Gx260 and after i properly installed it and then restarted my PC. I went to the device manager and there where still...
Hi
one thing with GX series is that there were multiple network adapters used. if this is the onboard i would try this driver from dell's site.
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R54402&SystemID=PLX_PNT_P4_GX260&servicetag=&os=WW1&osl=en&deviceid=2811&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&fileid=64589
if you dont have internet access on your gx260, youll need to download to another computer and then transfer it by flash drive or external hard drive.
once you have the driver on your gx260, then;
1. If you installed any of the network management utilities from dells site, uninstall those.
2. in device manager, find your network card, click on it and then remove it from the device manager.
3. shutdown completely (not just a restart) and then power up. all the new hardware prompts to come up and hit cancel to any of them.
4. find the dell driver package R54402.EXE, from wherever you have saved it to on flash drive, external hard drive or gx hard drive. double click on it to run.
5. once the installation is finished, reboot again.
If this doesnt solve it then there are several other drivers, but this is the most commonly used one.
If you still have problems with it, then reply in here and can help you further.
Hope this helps. and if it does, please dont forget to rate.
Feb 18, 2010 | Dell OptiPlex GX260 PC Desktop
Wireless router
You need a network card that is functioning to connect to anything.
If your network card in the desktop stops functioning, you will need to replace it (or, if it's built into the motherboard, add a card).
Unless you have a wireless card also installed, you cannot connect wirelessly.
Dec 19, 2009 | Dell OptiPlex GX260 PC Desktop
What ethernet driver do I need for dell optiplex gx260. There is no ethernet card. Just a slot for the enthernet cable.
check the Device Manager,
Go to Desktop/My Computer/Right Click/Properties/System Properties/Hardware Tab/Device Manager/look for Network Adaptor/ Expand it by clicking the + sign/Do u c any Ethernet Adaptor there or any yellow ? mark there....
If u dont c any Netwrok Adaptor then u dont have a network card installed in ur PC, if u have one then it will show up there, and if u dont ahve the correct driver or if's not installe dproperly then u will have the yellow ? amrk or an ! mark....
then in that case u will need the corect driver for the card to work....normaly Windows installs the required drivers for netwrork cards.....
Dec 17, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex 260 Went Mute On Network
Some cables can be ok on test but one of the wires can be loose inside the cable and it will prevent pockets to be sent out and received but will test as ok. not that often but i have seen it before.
Dec 10, 2009 | Dell OptiPlex GX260 PC Desktop
I am trying to connect to a wireless internet network
If you have Wireless networks available, and you just need a network adapter for the system, here is a good suggestion:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130111
The adapter connects to the system via USB, and setup is pretty simple
Sep 30, 2009 | Dell OptiPlex GX260 PC Desktop
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
Ethernet does't work
The yellow signs indicate the device driver is bad. Right click on the device and click on update driver...that should do it..if you have any questions let me know.
Rate it don't rate it I don't care :)..
Feb 28, 2009 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
167 people viewed this question
Alun Cox
