Question about Intertherm Heating & Cooling
Heater comes on but its not hot enough to warm house
Keeps running cause its not heating enought to warm the house
    Problem Solver:
  • 6 Answers
Is this a heat pump? if so its possible its not charged properly, if youre running on your strips , maybe one of youre sequencers is malfunctioning.. heat pumps arent able to pull enough heat into the house below a certain temperature, then you have to switch over to emergency heat. reply
Posted on Mar 02, 2009
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to bosch-climate.us to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
The water never gets hot when on normal settings
This time of year the water comming in the house is much colder and heater has to work a lot harder to heat 40deg. water than ot does to heat 70deg water in the summer time. its normal.
Jan 09, 2013 | Water Heaters
ONLY WARM AIR FROM HEATER, REPLACED THERMOSTAT, STILL ONLY WARM AIR. UPPER RADIATOR HOSE & HEATER CORE HOSES ARE HOT.
The next possibility, if you haven't already thiught of it, is as simple as making sure there is enough water/antifreeze solution in your radiator. If the level is too low, your hoses will get hot, but there will not be enought water to circulate into your heater core.
Dec 17, 2010 | Ford F-150 Cars & Trucks
Front heat works, but rear blows cold air only
With your front heat working the most likely cause for the rear heat not to work is that there is an obstruction in the line that is preventing the warm coolant to get to the rear heater core or the rear heater core itself is plugged and not circulating. Another possible cause could be low coolant level where the system has enough coolant to provide the front system with enought warm coolant but not the rear system. Hope this helps
Dec 30, 2009 | 2004 Ford Expedition
On a 2001 YukonXL the rear heater does not blow warm air.
i need to know how to reset the code on my 2003 ford windstar i did not get the code when i got it. it is used
Oct 14, 2009 | 2006 GMC Yukon Xl Denali
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Does not put out enought heat
Hi this is tech crazy
the solution and reason to the problem mentioned by you is as follows:
As cold water comes in, it remains at the bottom of the tank because it is denser than hot water. If you use the hot water faster than the heating elements can heat the incoming cold water, and if you consume all of the hot water that the tank holds, you run out of hot water in the middle of your shower. If this seems to happen too often, it could mean that the bottom heating element in an electric water heater has burned out or that your water heater is too small for your house. Or it could mean that you are taking really, really long showers.
Hope this helps u a lot
Please do rate me on the above said solution
Feb 04, 2009 | Empire RH35 Mid-Size Heater
1996 nissan altima keeps running hot new thermastate
There are a few things that can cause your car to run hot. Not enought antifreeze is one. It could also be your cooling fan is not working, a colgged heater core, colgged radiator, thermostat is stuck closed, leaky water pump, or coolant temp sending unit. Hope this helps.
Dec 21, 2008 | 1993 Nissan Altima
2000 Jetta Heater Not working
2000 jetta warms up when idling, but gets cold as soon as I start driving.
Dec 17, 2008 | 2000 Volkswagen Jetta TDI
Heating & Cooling Logo
154 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
