Question about Linksys Wireless-G WRT54G Router
WRT54G router working fine but need to turn on security.
The router locked up and my son talked with Time Warner cable to resolve the issue but they didn't security enable the system. How do I turn on the security??
  • 523 Answers
Well , go the web browse and put the default ip idress for the router which is 192.168.1.1 , then put the user name and the password, so u can logon ( default user name is : admin) and sometimes the password is : password) but just check your configuration notes coz may be i changed this, after you logon to the router you will see the setting and there is security and wirless security, if you need security for wirless just create name for your wirless and add password. if its general security just enable and disable buttoms, but donot forgot to save the changes.
Best Regards
Posted on Mar 01, 2009
    Problem Solver:
  • 18 Answers
With the wrt54g you need to open a internet browser and navigate to 192.168.1.1
a security screen will pop up to which the username is "admin" and the password is either "admin or blank, (unless you specified otherwise when running the install.
once in click wireless then security in the sub menu (under the wireless link you just clicked) then fill in the boxes
Router was fine last night - but the two wireless computers in the house are unable to get online this morning. What lights are supposed to be "lit" on the front? I see Power wlan and Internet are lit now.
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Open the router page (192.168.1.1)
2.Enter the username and password (by defualt password is admin and leave the username blank)
3.In the router setup page click Wireless and fill the sections and mentioned
Wireless Network Mode-Mixed
Wireless Network Name- As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Now click Wireless Security and select the Security mode as WEP
5.WEP Encryption should be 64 bits
6.In the Key1 enter a 10digit/10 letter password and click save settings.
7.Click Advanced Wireless Settings and fill the section as mention
Beacon Interval-75
Fragmentation Threshold-2306
RTS Fragmentation-2307 and click save settings.
8.Turn off the router for 30 seconds and then turn it on and try to connect your laptops.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys Wireless-G WRT54G Router
Can't get my son's hp Mini to connect to our router. Secured or not. It has worked on other routers before.
My guess would be that the 'dynamic' IP address cannot be resolved properly on your home network: try using a Fixed/Hardcoded IP address in TCP/IP Internet Protocol for your son HP Mini. Let me know how you go.
Dec 31, 2009 | Linksys Wireless-G WRT54G Router
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
I have a linksys WRT54G wireless router set-up. The problem is when I add the security features (to keep the neighbours from hijacking my signal) my son's MAC laptop and Play Station 3 won't work.
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 10, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
I have a WBR 2310 and I have to reset it every time I use it. It worked fine when I was with AT@T but when I switched to Time Warner cable it will not work for very long without unpluging it. My son...
YOU don't need to downgrade.
you can reset the router for 30seconds and set up the router from the start.
After resettingsthe router unplu the power cable to the router and plug it back in.
Set up the router from the start.
Click Here for more info
Oct 21, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Linksysy asks for a network key (Wep key or WPA key)
1. Using a computer that is wired to the router, access the router's setup page by typing 192.168.1.1 on the address field of your browser.
2. By default there is no username and password is admin.
3. Once you're in the setup page, click wireless then there is a sub tab there called wireless security.
4. You will find there the wireless key that is enabled in your router.
Nov 08, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
119 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
