Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan generator MODEL 7NHM FA 26106 F
What should be the fuel pump pressure, I have 4 psi which does'nt seem high enought.
  • Anonymous Apr 27, 2009
    i have the same generator except a b instead of an f, my fuel pump went out and its the old rotary type ($180.00)on ebay. onan mechanic said he would replace it with a newer electric pump...from the searching i have done so far 4psi is plenty, as it only takes 2-4 psi to run a vw or almost any motor under 150 hp.....here i found a good replacement. it's 1.25-1.75 psi.....hope this helps
    http://www.pegasusautoracing.com/product...
    Scholar:
  • 79 Answers
4psi is the correct parameter for this unit.
Posted on May 10, 2009
Why does it run only in the start position?
Hello Martin, Your generator might have a low oil pressure shutdown switch. First check the oil level. If oil level is low, fill oil to proper level. If oil level is fine, I would install an auxiliary oil pressure gauge . If oil pressure is normal, I would change the oil sender unit. If oil pressure is low, I would change the oil pump.
Aug 03, 2015 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
How to fix onan 6.5 rv nhm gasoline generator starts but won't keep running unless you hold in start switch on
The power for the run side of start switch is not making it to the coil. Check wires and switch.
Jan 17, 2015 | Cars & Trucks
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Onan generator fuel pump
Did you change the pump with the correct Onan pump, these are special low pressure pumps, and automotive pump will not work and can cause dangerous flooding and carb issues.
Jun 24, 2013 | Electrical Supplies
Have a 2.0kva-fr/26119 onan genorator which runs for 5 minutes and stops can you be of any help
If it stops after 5 minutes whether under load or not, and assuming the air filter, plugs, and fuel filter are new and or clean. The fuel pump is suspect. If it is in a motorhome try conencting it to an external fuel source that is at the same height as the generator. Then higher than the generator. If the problem persisits replace the fuel pump. Or just check fuel pump pressure with a gauge. BE CAREFUL do not use an automotive fuel pump Onan have special low pressure pumps, so use OEM part
Nov 13, 2012 | Onan Cummins 300-5332 Generator Switch and...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 onan emmerald 3 NEH bad fuel pump.
As long as the pump puts out 3.5psi to the carb, it should do the job.
Mar 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
315 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
