Lenovo Core 2 Duo T7200   PC Notebook
Problem for Lenovo Core 2 Duo T7200 (2.0) (0689E5U) PC Notebook
Kernel doesn't recognize complete memory
By pawa - usenet poster
Lenovo Z61p, Intel Core2 Duo T7200
I have 4GB RAM installed and BIOS recognize 4GB RAM.
Linux kernel (Ubuntu-7.04, 32bit-PAE and 64bit, openSUSE-10.2 32bit-PAE
and 64bit) tells me: only 3GB of RAM are installed.
Any other user with a 4GB Thinkpad? tytso?
What can i do? Please help!
Regards
Frank
To unsubscribe from this list: send the line "unsubscribe linux-kernel" in
the body of a message to
More majordomo info at #
Please read the FAQ at #
Best Solution
posted on Aug 02, 2007
Very Helpful)
man1
Rank: Apprentice
Rating: 0%, 0 votes
# is likely your problem, although
why you can see 3gb instead of only 1gb of ram, idk... maybe something
ubuntu specific...
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
The 945 chipset used in the Z61 can only address 4GB of physical address
space and your BIOS is using some of this for PCI and other bits of
hardware. That only leaves 3GB for RAM. I believe that this restriction
is mentioned on the IBM website somewhere.
Matthew Garrett |
Was this helpful?
Yes
No
Solution #3
posted on Sep 23, 2008
Not Rated)
aruparup_nan
Rank: Apprentice
Rating: 100%, 1 votes
cheak vga sharing mamory into bios
Was this helpful?
Yes
No
Solution #4
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 00000000bfed0000 (usable)
BIOS-e820: 00000000bfed0000 - 00000000bfedf000 (ACPI data)
BIOS-e820: 00000000bfedf000 - 00000000bff00000 (ACPI NVS)
BIOS-e820: 00000000bff00000 - 00000000c0000000 (reserved)
BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fed00000 - 00000000fed00400 (reserved)
BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ff800000 - 0000000100000000 (reserved)
Yes, that's the problem. Your BIOS/chipset only provides about 3070MB of
usable RAM to the OS. Unless there is a memory remap option in the BIOS
that you can enable, there's not much you can do about it.
Robert Hancock Saskatoon, SK, Canada
To email, remove "nospam" from
Home Page: #
Was this helpful?
Yes
No
Solution #5
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
On Samstag, 30. Juni 2007, Robert Hancock wrote:
Here is me dmesg output, fist 400 lines.
Regards
Frank
dmesg.txt
18K
Was this helpful?
Yes
No
Solution #6
Not Rated)
Melissa
Rank: Apprentice
Rating: 0%, 0 votes
With AMD's Athlon64 the answer would be "look into BIOS settings,
(re)map 3-4 GB memory above 4 GB address mark"..
The PCI-bus and all IO devices in it needs memory space within
the first 4 GB of physical address space. Some devices support
64-bit addresses in which case they can access whole physical
memory, most probably don't, meaning that they can access only
memory in lowest 4 GB part of the space.
Original 8088 PC had 20 bit address space, and "huge" megabyte
of address space. Then came 286 AT era with 24 bit addresses
and "whopping" 16 megabyte address space.. then came 386 and
finally true 32-bit addresses -- but ISA-space VGA aperture had
to be in there still.. and to gain access to of that memory
located "under" that VGA aperture, there was mapping...
Now the VGA aperture mapping is no more, but the PCI has similar
requirements - albeit with bigger apertures.
So, what does your BIOS have hidden in "advanced" menus (most likely) ?
Something about "remap (PCI?) memory above 4 GB" ?
Regards, Matti Aarnio
Was this helpful?
Yes
No
Solution #7
Not Rated)
Melissa
Rank: Apprentice
Rating: 0%, 0 votes
Please post your bootup dmesg output. If your chipset doesn't support
memory remapping above 4GB or the BIOS doesn't enable it, you won't be
able to use all 4GB of memory.
Home Page: #
Was this helpful?
Yes
No
Popular Solutions for Lenovo Core 2 Duo T7200 PC
Questions and Unsolved Problems for Lenovo Core 2 Duo T7200 PC
Do you recommend Lenovo Core 2 Duo T7200 (2.0) (0689E5U) PC Notebook?
Answer
Answer
hi, I have an amilo li1705. When I press the power button: the fan spins & immediently... (More)
Answer
can' rotate image on my monitor plugged into Toshiba laptop - rotate feature disactivated
Answer
Im trying to upload music onto my sandisk adapter to use with my motorla Q cell phone..I have a... (More)
Answer
I have a Gateway M465-e laptop. The hard drive is detected in the BIOS and works fine on another... (More)
Answer
I have an Acer Extensa 5630 EZ laptop. When I boot it up it gives a 5 times blick of the orange... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , FL
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
