Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore bagless 339123
Can anyone tell me how to connect the on board tools correctly, when attempting to use them...there is no suctions. It performs beautifully on my floors but when I want to use the wand or hand brushes there is no suction at all. I have been on every site and there is no manuel and I did speak with a woman at Sears, and she couldn't find a manuel either. I just know I am doing something incorrectly, but damn if I can figure out what...
  • 281 Answers
Take the filters out and clean them.try taking the filters out and turn it on and see if you have suction then.if you do the the problem is the dirty filters.ok if you still have a problem feel free to call ma at 314-628-9153 and i'd be happy to walk you through it.vacuum cleaners are my hobby i clean them up repair the then sell them
Posted on Apr 10, 2009
I have the DC07 model in the upright position suction is fine but when I drop the handle and go to vacuum it has no suction I've cleaned the filters and hoses for debri and still no suction and once I put...
Hi Chris,
I am very sorry to hear about this issue with your DC07 not picking up correctly. In most cases we may be able to resolve this issue by speaking with you directly and performing basic troubleshooting steps.
Please contact our US Dyson Helpline toll-free at 1(866) 693-9766 or our UK Support colleagues at 0800 298 0298.
Best wishes,
Jay
Dyson Customer Service
Oct 05, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
I have unscrewed all the screws and can't get bottom off.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore progressive bagless no suction however brush runs well .
remove all the filters and clean themon the bottom you have what is called an intake hose.you will see it as it comes up from the bottom and up on the backside.it connects to a fitting take the screw out and pull the hose away from the back.take a coat hanger and bend the end so its round then work it down through the intake hose,you should be able to push the clog out through the bottom
Mar 20, 2009 | Kenmore Progressive Bagless Upright with...
Only suction to attachments
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Feb 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Loss of suction on carpets
Wow...this is one of the only "bad suction" examples I have seen. I do know that after I clean my DC07, I have to make sure that the adapter pieces are seated properly, otherwise there's an air gap.
Have you tried connecting the hose instead of the main part? Is suction still bad? If so...then it's the motor. If not, then go back to check the adapter pieces or see where there's a blockage...look harder.
Call Dyson...their support is terrific!
Nov 05, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
60 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
