Question about Car Audio & Video
PARKING BRAKE COLOR SCHEME
WHAT COLOR ARE THE PARK BREAK WIRE ON 2004 CHRYSLER CONCORDE LX
  • 33 Answers
It is black with a yellow stipe and located @ BACK of JUNCTION BLOCK, GRAY Plug, Pin 11
Posted on Mar 01, 2009
WHY PARKING BREAK DEFAULT LIGHT 2004 XJ8 ?
if the park brake warning is on and the park brake is inop. there are several common problems with this system, the most likely causes are 1 the rear brake caliper sliders are part siezed or the pads siezed in the caliper frame 2 the wiring to the park brake motor open circuit or rubbed through on the rear subframe.3 the park brake motor has failed, you really needto get the fault codes out of the park brake module if the above checks out ok the above faults i have found to be the cause 9 out of 10 times. hope this helps.
Aug 09, 2014 | 2004 Jaguar XJ
I need a FREE 1992 Toyota Camry taillight wiring diagram. My side rear park lights come on but my park lights that work with the brake lights don't. I changed the bulbs and tested everything. I narrowed it...
brown wire is your park LT yellow Left-turn green right-turn. Now the break light my be on it own wire it is red black is ground. but if you have a test light see if the brown wire turns on the test LT when you turn on the park LT or what wire light up when you step on the break pedal. and so on.
Feb 25, 2010 | 1992 Toyota Camry V6
I need the wiring diagram for this deck. Which wire is the one for the parking brake?
i need the wireing diagram for this deck which wire is the one for the parking break
Nov 30, 2009 | Clarion MAX385VD Car DVD Player
Chrysler concorde car wont shift from reverse to park
it sounds like your gearshift cable is broken..if you can jack up vehicle and support it safely,get someone to move shifter and look on driver's side of transmission and see if linkage is moving on trans..linkage is up near top of trans..i have seen this problem before
Jul 30, 2009 | 2000 Chrysler Concorde
Key stuck in ignition when in park in 1999 Chrysler Concorde
When the car is in park, push the shifter firmly up past park and keys will come out. This is a very common problem with GM vehicles. The pins wear out easily
May 05, 2009 | 1999 Chrysler Concorde
Parking brake hook up
This wire goes to the "Hot" side of the parking break switch... When the Parking Break is put on, a switch is closed, thus putting an "Earth" on this wire.. Ya can often bypass this by connecting to earth. Sometimes this wire can be "Hot" +12v so B4 doing anything with unit "On" check this wire for any Voltage.
Aug 05, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
