Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Posted on Apr 17, 2009
Furnace will not turn on even after the thermostat is programed. Thermostat is a Hunter 44155c
5 a. Check the Heat/Cool function switch to ensure it is set to the desired position. 5 b. Wait. There may be as much as a 4-minute delay before the system turns on or off to protect the compressor. 5 c. Check the circuit breakers and switches to ensure there is enough power to the system. 5 d. Replace the batteries. 5 e. If applicable, make sure the furnace blower door is closed properly. 5 f. If your system has 4 wires, ensure the jumper wire is installed between the RC and RH terminals.
Feb 03, 2015 | Hunter Dryers
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
Both the fan and the light stop working. What are the first things to try?
Good way of asking for help!-- Thank you!
First make sure the circuit is not tripped at the Circuit Breaker--
(Are other lights on the same circuit still working OK?)
You will need to verify which breaker controls the voltage to this fan--
and you will need to turn the breaker OFF, while dismantling the fixtures.
Can you communicate with someone at the Breaker Box, while you work safely?
Have them turn the circuit on when you are safe and ready -- and reading voltage, etc.
Next-- Do you have a dimmer switch, (or just a wall switch) on the wall?
Do you know if the power is supplied to the ceiling, thru that wall switch?
If so, check to see if the dimmer or the switch has power coming in and out at the wall, and heading up the ceiling supply wire.
If the power is supplied at the ceiling, then you are going to have to get a safe ladder, and remember Ladder safety rules!
The tough part, is getting the heavy fan and light assembly safely down, where you can make some voltage readings at the supply circuit wires at the ceiling--
Maybe you have found a loose wire nut by now?
Or maybe a defective dimmer or wall switch?
Or what are you observing at the junction box, and the fan motor now?
Tell us more-- and we'll see if we can help yo to the next step.
Mack B,
Jan 18, 2011 | Hunter Ceiling Fan Control Switch
Keep poping the breaker on instllation
Check your wiring for short circuits. If you turn the switch on and it pops it may be in the switch box or up in the fan box. Also make sure the fan blades spin freely. A motor overload or short circuit would be the only reason for the breaker tripping immediately.
Jan 10, 2010 | Hunter Sontera 52" Ceiling Fan with...
I tried to change the remote codes on the fan and remote so it would stop turning on and off the fan in the other room but I can't get it to work.
When I changed the dip switches on the Hunter receiver, I noticed that the remote would not work when set to the new code. When I set it back to the previous code, it would work, leading me to determine that the receiver has some basic memory. The solution was to simply cut the power to the fan at the circuit breaker box and the new dip switch settings now work.
This was not described anywhere in the manual of the Hunter fan I purchased, so a slight oversight by the manufacturer.
Oct 12, 2009 | Hunter 27185 Remote Control
Short delay in ceiling fan light turning on
I also ran into this "problem". Installed five of the same fan last week and four of them have the light switched, one of them is on a 3-way switch. All the switched lights delay when turning them on while the "always on" light operated by pull string is just fine.
Could find no explanation in the user manual other than, as previous post mentions, new federal regulations that limit the wattage. One can assume that there is some sort of regulator inside the light fixture that needs to power up and/or run some sort of check to see how much power is being pulled by the lights.
The delay is super annoying, but I suppose all light kits are going to have this now. Thank you FEDERAL GOVERNMENT!
Aug 01, 2009 | Hunter Ceiling Fan Control Switch
Dash and shifter lights in 1996 jeep cherokee wont light
Hello and welcome to FixYa . Locate the dial that controls the brightness of the dashboardlights. If the control is not immediately evident. Make sure the brightness control is turned on. If it is and the lights aren't working, the problem may be a bad fuse. Check the fuse that controls the dashboard lights Replace the fuse if necessary. If just one part of the instrument panel is not lighting up, then you have either a burned-out bulb or a wiring problem.
Passenger side kick panel fuse breakdown for a 1996 jeep Cherokee Country
01 - 25A Rear Wiper/Washer
02 - 15A Radio, Cigar Lighter
03 - Empty
04 - 15A Passing Light
05 - 30A Blower Motor
06 - 30A (Circuit Breaker) Power Windows
07 - 02A ABS
08 - 20A Turn Signal Flasher
09 - 10A Radio/Clock Memory, Courtesy Lights, Glove Box, Cargo, Dome Lights, Telltales
10 - Empty
11 - 25A Headlamp Delay Module, Horn
12 - Empty
13 - 20A Power Door Locks
14 - Empty
15 - 15A Instrument Panel Lamps, Clock/Radio and Memory, Headlamp Switch, Parking Lamps
16 - 30A (Circuit Breaker) Power Seats, Trailer Tow
17 - 7.5A Instrument Cluster Gauges, Headlamp Delay Module, Chime Module, Overhead Console
18 - 25A Rear Defrost
19 - 05A Instrument Panel Lamps, Radio Illumination
20 - 5.5A (Circuit Breaker) Windshield Wipers and Washers
This should get you going. And you can always Ask Me.
Apr 27, 2009 | 1996 Jeep Grand Cherokee
Hunter ceiling fan remote control will not work
Are you talking about just activating the fan, or the tv as well? If you just need the fan, in the top plate where your fan is mounted into the ceiling, there is a box. This box has 4 switches that are turned on or off towards a number. You find that and then just open your remote up and set the switches in the remote to the identical numbers. I need help for the tv codes i lost the booklet, i need the codes for a daewoo.
Apr 26, 2009 | Hunter 20537 / 20538 The Vista Iron...
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
640 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
