Question about Frigidaire GLEB27S7A Electric Single Oven
How do you replace a upper door hinge on a Fridaire fgb24t3asa?
  • Frigidaire Master
  • 2,651 Answers
You would need to remove the unit form th ecabinet, at least partially, for the spring is atached to the lower frame of unit , so yyoull need to reomove the side panel to gain acess to this spring,simple hing e to change just a pain in the a** to try to get to!
Posted on Mar 01, 2009
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Oct 26, 2011 | Ovens
Repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time......
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Jun 25, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
May 15, 2009 | Neff B1421 Electric Single Oven
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
Nov 06, 2008 | Ovens
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Frigidaire GLEB27S7A Electric Single Oven Logo
85 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
