Question about Vizio L32 32 in. LCD HDTV
TRYING TO HOOK UP MY AUDIO SYSTEM TO MY VIZIO
I HAVE A 32' VIZIO TV I AM HAVING PROBLEMS INSTALLING MY AUDIO SYSTEM TO IT. IF YOU PLAY A DVD YOU CAN HEAR THE SOUND, BUT REGUALR TV THE AUDIO SOUND WANT WORK ANYONE KNOWS WHATS GOING ON.
    Sergeant:
  • 319 Answers
The TV should have a set of RCA outputs on the back of the TV. they are specifically labelled and believe they are on the R side if you look at the back of the set.
Hope this helps! rate well pls!
Posted on Mar 01, 2009
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
Have alot of buzzing noise when we play a DVD but not when watching tv.
Verify the AUDIO cables from the DVD player to the TV they could be defective (even if new)
push the PLUGES firmly so they are correctly seated, play with (shake/move) the AUDIO cables while playing a DVD to see if it's not a loose connection
Cheers!
Jan 14, 2011 | Vizio L32 32 in. LCD HDTV
Sound went out on vizio
Help people with this problems many times.Reset ur tv,by unplug,replug it an hour later.Go to the tv menu,go to AUDIO setting go down to reset,press that to reset,will return it back to factory setting the audio well return.
Apr 28, 2010 | Vizio VP322 32 in. Plasma TV
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
I can't get my Playstation 2 or Wii to work with Vizio tv
I bought a RF Switcher Phillips SWS2325W/17 ...with this I was able to hook up my Wii...TV...DVD...and Directv...works fine...hope this helps
Dec 23, 2009 | Vizio Televison & Video
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
How to hook up my 32" vizio lcd hdtv to my sanyo home theater
If your audio system doesn't have optical inputs you're going to have to use RCA (red and white) jacks.
I would suggest upgrading to a system in the future that does have optical inputs if at all possible. Excellent sound.
Jun 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
HOW DO I CONNECT MY DVD THEATER SYSTEM TO MY FLAT PANEL TV?
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand Televison & Video
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
209 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
