Question about OfficeMax 0M96431 Shredder
I NEED A GEAR FOR a Model[OM96993]Shredder,Where would i send to get one??Shuie
DX-PS10MC gear broken
Might have to go to eBay or Gumtree.
Mar 05, 2014 | Dynex - 10-Sheet Microcut Paper Shredder
Plastic GEAR 5403 07-1 B1
Here is a link where you can find a replacement: http://www.sportslinkup.com/shop/0-Fellowes-gear-1.html (Part Number 205993 OEM Fellowes Shredder Gear Kit for Model P-55C). They have the whole gear assembly.
I need the same for my P-57Cs shredder (broken stage 2 gear 540307-1. Hope it helps, good luck!
Dec 04, 2010 | Fellowes Powershred P-55C Shredder
TS3300 PAPER SHREDDER. I NEED THE SWITCH CABLE COMBINATION
where can i buy a gear for my paper shredder model ts 3300
Apr 26, 2010 | Tech Solution TS-4500 Shredder
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
May 26, 2009 | Office Equipment & Supplies
Need a drive gear for Bother's shredder Model DM65C
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 30, 2009 | Whitaker Brothers Datastroyer Shredder
Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
Good luck, Tom
Aug 18, 2008 | Office Equipment & Supplies
Does not feed paper
Had the same problem. The gears inside the shredder have worn out. I overfed the shredder with too much paper and caused the nylon gears to slip and strip away the teeth. Now the motor won't engage the cutters when you attempt to feed the machine. If your handy you can take it apart, find the gears, contact the manufacture and have them send you out a new set for that model. If not, then you will need to buy a new shredder. In my case, they sent out new gears, it took forever to receive, and when I did get them one gear was the wrong size. I had them send out a new one, and again after weeks it was still the wrong gear, even after sending them pictures! I am now buying a new shredder, and I am spending a bit more to get a more robust machine that can handle more of the workload I need.
Dec 15, 2007 | Fellowes DM8C Cross-Cut Shredder
Plastic drive gear from motor broken
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
edbwest@aol.com
Oct 31, 2007 | Cross Infoguard Shredder SX102M
OfficeMax 0M96431 Shredder Logo
101 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
