Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
No cinnection with my laptop
Router G plus Mimo router
I have checked all the indicator light and it looks good.
I have reset the router by inplugging the power and wait for a minute to restart, but still no connection.
In the beginning ( two months ago) it was very good. No any idea what to do.k you for your help.
Thank you for your help.
Regards
D. Gangadin
  • 40 Answers
Given the router was working and you haven't made any changes, and your laptop is able to connect to other wireless networks, it sounds like your router has suffered a hardware failure. Since it is less than 90 days old (the typical period in which you see failures of new electronics) I would suggest obtaining a replacement from the store you purchased from.
Posted on Mar 01, 2009
I have a belkin wireless g plus mimo router and im trying to hook up my new laptop for the wireless access..my other computers are on this currently but i cant find my box to get my access code to hook up...
check network connections on other pc`s.......... ware the code is entered ...
some pc`s allow you to "show code" rather than just the stars
but also check the router as some times the code is on a lable underneath....
might help....good luck..............
cheers
Mar 22, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Looking for driver for a belkin wireless G Plus MIMO Router. Model # F5D9230-4 ver.3100 Thank you
This looks like the correct one:
http://en-us-support.belkin.com/app/answers/detail/a_id/523/~/f5d9230-4-wireless-g-plus-mimo-router---firmware-update
(select download Version 3xxx Firmware )
Feb 16, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can i reset my Belkin Wireless G Plus MIMO Router it cannot connect for an internet connection
  • Locate the small master-reset pinhole on the back of the router. The pinhole is located directly to the right of the Ethernet port labeled "connection to modem."
  • 3
    Soft-reset the router by placing a sharp object, like a push pin, into the router hole. Push inward and immediately release the button. The lights on the router will flash and then the "Power/Ready" light will start to blink. When the light turns solid, the router is reset and ready to use. This reset does not restore the router to factory settings. It refreshes the software and is similar to rebooting a computer. If you want to restore the router to the factory settings, skip this step and move to step four.
  • 4
    Master-reset the router by placing a sharp object, like a pushpin into the router hole. Keep the pin pushed into the hole for 10 seconds. The lights on the router will flash and then the power/ready light will start to blink. When the light turns solid, the router is reset and ready to use.
    Read more: How to Reset a Belkin Wireless G Plus MIMO Router ' eHow.com http://www.ehow.com/how_6759000_reset-wireless-plus-mimo-router.html#ixzz16uTbPLCW
  • Dec 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Just got a router from my buddy and i want to hook it up.
    Take a look here.
    (if you need to reset the router to factory setings, push something into the reset hole on the back of the router)
    http://www.pcwintech.com/wireless-setup-belkin-g-plus-mimo-f5d9230-4-v5-belkin-firmware
    Jul 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    The internet lights are off, suddenly the internet lights went off together with the wireless light
    looks like the router was reset. Reconfigure it with the cd and it should be fine. A router update or a power surge could possibly force the router to factory settings
    Apr 11, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    I just reset a belkin g mimo router I cant conect
    connect your laptop to your router via patch cord to be able to access the router configuration, then configure it, change the wep keys..etc
    hope this thing help
    Jan 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Bought an Belkin wireless g plus mimo router at
    You maybe able to reset the router to the factory default by powering up the router, press and hold the RESET button at the back of the router for 7 secs..
    Then open a browser and type in the IP configuration address to reconfigure the router.
    Sep 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    I cannot connect to internet with ps3 using belkin g plus mimo..
    you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
    Aug 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin router wireless g plus mimo router only seen by one laptop
    First thing to try here is to change the wireless channel of the router to 11, 6 or 1 and check which one will be broadcasting the siganle for your, but aftet playing with the channel what will be the next step is to reset the router by pressing the reset reset button on the router for 15 seconds while the power is ON then after that you will need to reconfigure the router and that should fix the problem....
    Hope that helps..........
    Oct 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin Mimo Router
    If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
    Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
