Question about Solis Maestro G385 Electric Burr Grinder
Solis Maestro Plus: Grinding Adjustment does not move and can not take out Grinding Ring
Dear Tech support,
After taking of the bean hopper I can not lift the grinding ring as suggested in the manual (I do not want to force it to much with a screw driver). After cleaning and replacing the bean hopper.. the adjustment dial only moves a few centimetre, not enough to grind for espresso.
Do I need to open the grinding machinery for this? How do I do this.
Thanks a million,
Stef
Cannot move the grinding ring adjustment.
  • Solis Master
  • 19,396 Answers
Try cleaning the grinding ring with a thin pointed tool.
Posted on Mar 01, 2009
  • 1 more comment
  • Ginko
    Ginko Mar 01, 2009
    The grinding ring cannot be removed because is stuck with coffee residual and oil.
    Try removing debris from around the edge of the grinding ring, use a pointed knife or a pin.
    Be careful not to damage the parts doing this.
  • Ginko
    Ginko Mar 01, 2009
    If you still cannot remove the grinding ring, then call Baratza at their toll free line: 877-701-2021 8:00am to 5:00 PST Monday thru Friday
    they can follow you step-by-step and help you in disassembling the unit.
  • Ginko
    Ginko Mar 01, 2009
    Do not put any liquid inside the grinder.
    To clean the residual ground try also turning the grinder upside down, and tapping gently the bottom and the side of the grinder.
    With the grinder still upside down try rotating the bean hopper
    back and forth so to get rid of some of the ground stuck in there.
    Remeber that to be removed the bean hopper must be rotated counter clockwise until it stops and the notches are in the right position.
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
How to adjust new baratza maestro plus I had a solis maestro previously that, when dialed all the way up, did produce a grind fine enough for a good espresso, but this new machine does not. I have taken...
I, just adjusted the the solis 167; first remove the Bean container by turning counter clockwise and the pull straight up) then remove the timer dialer (time/quantity control), then remove the cover by lifting the locking tabs (2 slots each side) with a flat screw driver. Once you removed the cover. Pull straight up the the white ring with the metal cup. Now you see a dark ring which is clicked on the with unit. When you look under the ring you an see little holes all along the white unit (that's important because you need to mark your old position). After marking the thr ring on the white unit, pull off the the dark ring by slowly pulling the ring outwards just on 2 places on the ring where there an small hole in the ring (there are 4 holes). When you turn the ring you will see 2 nobs, now place back the ring with the nobs 2 places further(clockwise) than the old position. You have just adjusted the grinding control! Place back all parts in reversed order. To place back the Bean container you must be aware that there are 2 black nobs in the machine and 2(different sizes!) on the container, they must be placed in a cross.
I trust you will hav succes. Don't turn to far at once because you have now modified the machine and this could damage it! I will assume no responsibillity for damages! Masta NL
Jan 24, 2010 | Solis Maestro Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Maestro Burr coffee grinder stopped grinding
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Apr 04, 2009 | Solis Maestro G385 Electric Burr Grinder
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Hi
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Jul 12, 2008 | Solis Maestro G385 Electric Burr Grinder
Solis Maestro G385 Electric Burr Grinder Logo
134 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
