Question about Kenmore 24 in. 16032 Built-in Dishwasher
The dishwaher dose not empty even with the pump running
I'VE CHECKED THE DRAIN FILTER, REMOVED THE PUMP, CHECKED THE DRAIN OUTLET FROM THE DISHWASHER BASE TO THE PUMP, CHECKED THE DISCHARGED HOSE FROM THE PUMP AND THERE IS NO BLOCKAGEAND REMOVED THE PUMP AND ENERGIZED THE PUMP WITH SEPERATE POWER CORD.THE PUMP SPINS FINE BUT IT DOSEN'T PUMP WATER. WHAT ELSE COULD IT BE? HELP!!!
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasherthe dishwaher dose not empty even with the pump ru - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 26, 2010
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Jan 11, 2009 | Bosch 24 in. SGS43C12 Classixx...
Drum wont empty...have checked pump, seems to be working becasue some water is being pumped out..have checked filetr to pump and removed a couple of small buttons..outlet hose seems fine because initial...
It obviously is related to the pump and outlet hoses.
If it is a tap in waste then check for obstruction there,
Remove drain hose completely and run water though it to make sure it is fully clear.
Check inside the pump itself for any obstruction , if you are satisfied that every thing is o/k, then as a last resort, fit new pump.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Does not drain water after wash/rinse cycles
check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Sep 04, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
MY DISHWASHER IS NOT DRAINING. I REMOVED THE DRAIN IT DOESNT SEEM TO BE CLOGGED .
When you say that you removed the drain, are you talking about the filter screen and you removed all sediment from previous wash cycles? If so, does your dishwasher drain into and thru a garbage disposal in under your sink? Sometimes that gets clogged and when the DW tries to drain thru that, it just builds up and doesn't empty the DW properly. A quick yet not so painfree check can be to detach the dishwasher drain hose from wherever it is clamped on ( under the sink ) and run the dishwasher thru a cycle //but allow it to drain into a good sized bucket.. If that works OK and you have a good flow .. then chances are your drain system is restricting it from draining.. Conversely, if the DW drains very slowly then there is a good chance your pump, the line into or out of the pump may be clogged or the pump itself is malfunctioning.. Those are the main components to look at..Hoe that helps you !
Aug 19, 2008 | Bosch Dishwashers
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Leak from dishwasehr drain
Creilly, there is a clamp that holds the boot to the sump. It might be where you are leaking. This is not too complicated of a deal. You can either pull the dishwasher out to inspect it or drop the motor and pump assy with the boot attached. I have removed the pump and motor assy. by removing the drain hoses, disconnecting the wire harness. On the inside tub you would have to remove the filter screen and sump filter. The boot that clamps to the pump will be exposed. Push it in, remove the motor hanger, fold the boot over and pull out. As long as you have a couple inches of clearance from the motor bottom to the floor you can do it that way. To answer the first question, this is not a common complaint. Catriver..post back.
Mar 12, 2007 | GE Profile PDW8480JSS Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
109 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
