Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark x9575 says line error when faxing - Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
  • 628 Answers
Probably noisy phone line. Even if voice is good, fax machines are more sensitive to line noise. Make sure the phone connections are secure and tight. Try another phone outlet if you can. Then try it from another location.
Posted on Mar 17, 2009
Need an air print driver for iPad
The Lexmark X9575 is not compatible with the AirPrint technology. However, it can print photos from you iPad through the LexPrint application. Please refer to the article on this link: http://bit.ly/UG4qYI, for more information about the LexPrint app.
Dec 13, 2012 | Lexmark X9575 Wireless Professional...
Lexmark x9575 all in one keeps restarting after slecting scan\copy and fax I have un-installed and re-installed the drivers + reset printer to default factory settings - no change
Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
May 31, 2011 | Lexmark X9575 InkJet Printer
Message no lexmark X9575 fax printer installed
Hi. Try to use and install the software again using the installation cd. When it runs, it should pop up the window with 3 options: Install a printer, Update/Upgrade, or Install additional softwares. Choose install additional softwares. In the next window, place a check mark in Fax solutions. Then, continue and finish the installation. If you don't have the cd, software can be downloaded by going to this link to the Lexmark website. http://bit.ly/d9TDnb . Download the compatible driver for your computer. Run the installation. Hope this helps.
Mar 09, 2010 | Lexmark X9575 InkJet Printer
I have a Lexmark X9575 that leaves lines in the middle of the sheets ONLY when using the Top Loader.
this seems to be problem with the scanner part of the printer.. please contact Lexmark tech support to get a new printer if it is under warranty.
For technical support or customer service in
North America, please call
1-800-LEXMARK (539-6275)
Oct 02, 2009 | Lexmark X9575 InkJet Printer
Unable to install the printer drivers Lexmark X9575. I get error while installing the printer drivers
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall, please follow the steps given below:
1. Click "Start" and "All Programs."
2. Go to the "Lexmark X9500 series."
3. Click "Lexmark Uninstall."
4. Click "Next."
5. Click "Finish."
6. Click "Restart Windows" and unplug the USB cable.
To access the Lexmark X9575 vista driver, you may copy and paste the web address given below:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:87:0:0&emeaframe=&fileID=15198&searchLang=en&os_group=Windows%20Vista
Please use the following steps to download the Lexmark X9575 Vista driver to your desktop:
1. Select "Window Vista" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Apr 27, 2009 | Lexmark X9575 InkJet Printer
X9575 phone conflict
You may have wired your FAX and Phone up wrong. Go to the following website to view the Manual and try going to page 28 and try wiring it up again.
http://www.lexmark.com/publications/pdfs/2007/9500/winug/en/lxdouser.pdf
Thank you for using Fix Ya!
If you still have questions, let me know.
Don;t forget to rate the overall satisfaction of this solution.
Feb 19, 2009 | Lexmark X9575 InkJet Printer
X9575 fax & recieve phone calls
Yes most of the Lexmark printer work on the same formula ...
Good luck ....
Dec 05, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I can't receive a fax
pull it up in device manager select properties and got to the advanced tab there is where you will find the option
Jul 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
119 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
