Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
Ariston Oven power trip
The oven used to work perfectly, but now it trips the power when I try to switch it on. I have changed the fuse but it is still happening, so it doesn't work.
  • 298 Answers
Take off the back cover and check whether the terminals on the heating element are touching it. Normally caused by some earth leakage currents flowing from heating element to ground circuit.
Posted on Jan 20, 2010
Ariston L2020-causing electrical power trip
That is a very subjective question however I am assuming what is meant by the power trip is the breaker tripping. If it is a new install and this is the first few times it has been used it is probably an undersized breaker. If it has been operating properly for a while then it is probably one of the phases touching the other phase or earth. You did not state you have a CGFI so I am assuming you do not.
Try checking the manual to see if things are sized correctly.
Free Ariston Oven User Manuals ManualsOnline com
ARISTON Parts
http://www.appliancepartspros.com/
Mar 02, 2015 | Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Oven not working...despite changing elements
Go check your fuse box! The fuses should b labeled as to which one is which.when u find the one for your oven/range...flip both switches to it off then flip both back on. See if that works
Mar 28, 2011 | Ovens
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
661 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
