Question about Cisco ASA 5500 Firewall
I need a L2TP configuration for my PIX 515 and ASA 5505
I tried a many ways to configure L2TP tunnel with my ASA and pix from both XP and Vista. Even i referred many documents but i could not come up with a tunnel.i am new to this field kindly update me how to make it work
  • 73 Answers
You can do this, For your ref i hv given you a link
http://channel9.msdn.com/forums/9GuyAroundTheWorld/251722-Cisco-Pix-to-Windows-Vista-Native-Client-Using-L2TP-IPSec/
Posted on Mar 19, 2009
Replacing a PIX 515E with an ASA 5510
Best way to migrate is to take the configuration of the old PIX and TFTP it to a PC or other server for safe keeping.
Then boot up the ASA in a lab environment and TFTP the configuration to the new unit and reboot. There will be some commands that don't translate correctly, but you can compare the configurations to each other to make sure all the access lists and NAT statements get transferred across.
Keep in mind that the PIX and the ASA name their interfaces differently, so there may be errors when you transfer the configuration. You can edit the configuration offline with something like Notepad and change the names of the interfaces to have it work.
Jan 29, 2010 | Cisco ASA 5510 Firewall
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
How to configure MAC access list at PIX 515
The PIX is a layer 3 device, I cant say that I have ever tried to filter a mac address. I'm pretty sure you cant
Jan 02, 2010 | Cisco PIX 515E Firewall
Installation of cisco asa 5510 firewall
Hello kuniksh,
Look at the below link for all configurations
http://www.akadia.com/services/cisco_router_firewall.html
Do rate this solution!!!!
Mar 21, 2009 | Cisco ASA 5510 Firewall
PIX AND ASA Configuration
Voila un link pour un bon simulateur:
http://networksims.com/pix.html
Nov 20, 2008 | Cisco ASA 5520 Firewall
Site to site VPN between Checkpoint UTM 1 R62 and Cisco pix /Netscreen
I couple of points:
PIX has a few dislikes...
1. Pix does not like class A address, make sure you are using B or C.
2. The VPN subnet always has to be differant to the LAN.
3. Has to have a working DNS server.
4. Add static route, and last resort to main ethernet port that has the DNS & R62. (or 2 if on differant sub)
Hope this helps.
Dec 16, 2007 | WatchGuard Technologies Firebox X5000...
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Cisco ASA 5500 Firewall Logo
1,727 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
