Question about Carrier Heating & Cooling
I have a carrier Mod # 06dm337 for chilling water.....the lube oil pressuer drops off when I start up.....and low suction press....this is a medium temp unit....I think the L/O danfoss protection is working, because it shuts down the comp after a time delay.....I start with about 40 PSI oil press then goes to 0 with in 40 seconds......Why Why Please tell me if you have any ideas..I have cleaned the oil strainer,and cleaned the check valve,and checked the oil pump...seems to be OK what else.... Shawn Clementi
  • 1 more comment
  • smoore810 Mar 02, 2009
    I am useing R-22....I have checked the strainer,the check valve,the orifis,I took the oil pump off and checked the springs and keepers....put some oil in 1 side and then turned the impellar, seems to be pumping....now I am going to make new gasget for oil pan ,reassemble and try again.....I will let you know what happens from that point.....thank you for taking the time to help......I also want to know if I can troubleshoot the L/O press protection Switch.....Danfoss bellows type.....
    Thanks again,
    Shawn
    Thanks again,
    Shawn
  • smoore810 Mar 03, 2009
    Thank you very much.....that makes sence.....right now I just put the compressor back together and will add oil tomorrow.....and restart.....from there if I still have the same symtoms....I will check the TXV's.....thank you very much for the help with this process of elimination.....I will post the results when I find out difinativly what went wrong....
    Shawn Clementi
    Guru:
  • 462 Answers
Well I dont know what refrigerant your working wqith but I know the oil press sw's Ive dealt with open after a senmce of NO pressure Difference between Crank case and Oil pump Output pressure. You'll have to pump down the compressor and install an access tee for telling you what your oil pressure is and then subtract the suction pressure for true oil pressure. Usually the oil press sw is set at factory and is tween 7 and 20 psig. If it dosnt see this pressure a heater on the OP sw will energize and if the difference isnt senced withing the heater time limit it causes the points to open shutting off the compressor. If oil press is indeed low You could have bad oil, bad screen inlet to the pump or worn out pump or low oil. BEWARE LOW REFRIGERANT CAUSES OIL TO SETTLE OUT DURING A RUN CYCLE. So if you add some oil then Refrigerant Be ready to take the oil back out important to measure how much in so you dont take out too much. Low back pressure from anything from low charge to a TXV or other valve not feeding correctly. This pressure being low can allow oil to settle anywhere eccept tyhe crank case. The Refrigerant returning toi the compressor caries it back usually unless its piped in incorectly where the oil can trap OUT of the system and not be brought back. .
Posted on Mar 02, 2009
  • Farley Redfield
    Farley Redfield Mar 03, 2009
    You'll need to know what the cut out pressure is on your OP SW. And you'll need to know what the Suction and Oil Pump Pressure is. True Oil Press, is Oil pump Press - Crank case (or Back) Pressure.
    If your above this pressure the contacts in the OP should open and the Heater circuit de-energize on your OP SW. After you confirm you have Oil Pressure keep a close watch on oil level and refrigerant pressures. Im bettign your oil has setteled in your Evaproator (You did say it CHILLS WATER). IF this is all clear and it has ran like this in the past You mahave a leak, a bad TXV, or some other component Not allowing the refrigerant to flow 100% through the TXV or the evap thus trapping out the oil.
    PLEASE rate me accordingly ANd Thank you in advance.
Leaking oil tahoe
The rear seal of the engine could have started to leak but a loose oil pan or damaged oil filter could be a factor.
Apr 03, 2017 | 2005 Chevrolet Tahoe
I have a 2004 jeep liberty, when the vehicle is at a stand still the oil light comes on, as I start to drive and continue to drive the light goes out. Comes on again at times when standing still,...
1st thing to try is to replace the oil sinding unit, if the problem percets then have someone install a manuel oil pressuer gauge to check the oil pressuer at hot idle if oil pressuer is less then 10 psi at hot idle then replace the oil pump.
Aug 28, 2011 | 2004 Jeep Liberty
I have VW bora that the transmission had been rebuild with a new oil pump ,but now the oil pressure is only reading 75 PSI at 2000 RPM what can be the cause
You do not need huge oil pressure to have the oiling system do its job. Pressure can be low, like 20 psi and still lube and protect..... Too high pressure blows seals and the like.... The lubrication system and its pressure depend on all of the clearances to be tight enough (meaning oil pressure lubed areas like cam, crank mains, lifters, rods, etc. So, the top limit of the pressuer is controlled by a relief valve, usually on the pump or the oil filter. this limits the upper amount of pressure that you can develop.
Are you consuming, or burning oil? How many miles before you add a quart of oil? Factories claim a quart in 600 miles okay. But for me, I need 1500 to 2500 miles at one quart is normal....
But Your issue...Are there any other symptoms of anything?
Feb 18, 2011 | 2005 Volkswagen Golf
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
When I turn on my Keurig Brewer B60 It says not ready. It doesn't pull water to heat it and it shuts off after about 3 minutes.
Normal 0 0 1 94 537 4 1 659 11.1287 0 0 0 Try the following steps to reset the processor:
1. Simultaneously press and release “small mug” and “medium mug”. Immediately afterward press “menu” 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press “menu” once. Your LCD screen should say Brew 0:00.
3. Press and hold “medium mug”. While holding “medium mug” press and release “menu”. Immediately after releasing “menu” (while still holding “medium mug”) press “small mug”. Release “small mug” and “medium mug” at the same time. This entire thing needs to be done very quickly.
4. Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back in, turn it on and follow the instructions for priming.
Mar 29, 2010 | Keurig B60 Coffee Maker
Head pressure good low pressure good, but not cooling
r we talking about a split system? begin pump down by closing the high side then watch as the suction drops to zero or very close u should here the compressor loading. turn off the compressor open low pressure port and see if the refrig. is being held by the valves. if the refrig flows back to air handler thru suction in a/c mode most lkely compressor needs to b replaced due to bad valves. also whats the twmp drop across the coil
Jan 28, 2010 | Carrier 38CKC036 Air Conditioner
Hi everybody i want some help , iam a technision in air conditions ,i was fix a central ac carrier and i found that everything works good the compressor and the high pressure fan and indoor fan ,but the...
if the compressor is running - the suction pressure should be 65-75 psi - if it is very low - not enough freon - if it is very high - the compressor valves could be damaged - both will cause this
Sep 19, 2009 | Heating & Cooling
Oil pump flickering on 93 Camry
Acheep way to find out is had some power punch to the oil buy a quart for 6 bucks drain a quart of oil and put it in it the light does not xome on then it's fixed. if it still comes on check the pressuere sending unit it could be defective to.
Jun 16, 2009 | 1993 Toyota Camry V6
Low pressuere motor pump when i plug the vacumm drop 30 to 5psi
if your filter pressure is 30 psi it needs to be backwashed! Reson pressure drops when hooking up vacuum cleaner is reduced water flow will drop pressure
May 15, 2009 | Pentair 1.0 Hp Whisperflo Pump
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Heating & Cooling Logo
125 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
