Question about Maytag Dryers
Dryer #mde9606aya quiet + heavy duty dryer won't start. There is
There is powerto the dryer and i think the start switch might be a problem
  • 686 Answers
Check your thermal fuse when it goes bad either the heat element or the entire dryer won't work.
Posted on Mar 02, 2009
catriver
  • 878 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Posted on Feb 19, 2007
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
  • 1810 Answers
SOURCE: Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Posted on Aug 04, 2009
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
richroth
  • 9472 Answers
SOURCE: GE dryer heavy duty 7 cycle, just finished drying
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Posted on Sep 28, 2011
Testimonial: "Richard was quick to response and extremely helpful. I ended up finding out the problem myself but richard was there with tons of help with the most minimum amount of details... THANK YOU AGAIN RICHARD"
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
I have a Kenmore Elite Heavy Duty King Size capacity Quiet Pak gas dryer. The model # is 110.76922501 and the Ser # is MTO502806. The problem I am having is that the dryer sometimes does not start when...
the push to start switch holding coil is getting weak and can no longer either make contact or drop out shutting down the unit,there is a coil that energizes to hold the switch on and when the contacts or coil get weak the unit either wont start or start and drop out/quit,you can test this switch by bypassing it and if unit keeps running the switch is definitely bad then the unit is a whirlpool produced for kenmore by the 110# you provided so you need to order a switch either thru whirlpool or sears
Aug 22, 2011 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Apr 04, 2009 | Maytag Dryers
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
144 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
