Cut out with blank screen
I have just up graded my toshiba p100-240 laptop to its maximum memory of 4gb the machine does feel hotter and now freezes after about 1 hour of hard work so I fitted a higher qualaty of memory and it still freezes with a blank screen could this be over heat fault even the key board now feels warm
  • pontelemon
    pontelemon May 11, 2010
    If you put back the old memory?
How to expand ram
I depends when your computer was made.
It seems that from the information your have given, that the maximum memory of your computer is 4GB. You have to specify / choose the amount of RAM at the time of purchase (2GB or 4GB) because the RAM is soldered into he computer.
16.April.2014
Feb 14, 2014 | Apple Macbook Air 11" A1370 Lcd Complete...
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
My problem is that my laptop is too slow. OS Home Vista Basic. Memory was upgraded to 1GB. Now I want to upgrade the memory. Can this model be upgraded to 4GB. this means I will install two 2gb. Thanks.
I would suggest you not to install 4GB RAM on windows, keepp it to 2GB.
Use MAC or Linux instead, they have a performance also.
If you want to use 4GB RAM then you will have to switch to 64bit Windows, you should not use 4GB or moree on 32-bit Windows OS.
Oct 23, 2009 | Toshiba Satellite A205S4567 Notebook
I have a Toshiba A215-S4697. It should take up to 4.0 GB of memory. But when I install 2 4GB memories it only shows 2 Gb. Why is that?
u have to put 2 2GB memory to get total 4GB or one 4GB at a time..becoz ur maximum support is 4GB..if u put more the memory will be half..
Dec 12, 2008 | Computers & Internet
Toshiba m105-s3084
Number of Slots:
Slot 1 Slot 2 Normally you will find the 2 slots, one above the other.
Each memory slot can hold DDR2 PC2-5300,DDR2 PC2-4200 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory. Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. Make sure that both are fully seated prior to powering up the laptop.
Nov 05, 2008 | Computers & Internet
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
4gb ram wont work
its not XP it will be the maximum capabilities of the amount of memory the laptop can handle, please refer to manual for max amount, i would suspect 2GB max
Aug 19, 2008 | HP Compaq 6720s Notebook
Blue screen Freeze!
perhaps your OS has died................one thing is sure ..... your display is ok u have an OS problem
Jul 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Brand new gateway m-6846 vista 64bit
The maximum amount of memory that your system can use is actually limited in two ways — not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept.
For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used only by high-end users), your system will see (and utilize) only 3GB or 3.5GB.
Relax, there isn't a problem with the memory. Windows allows for 4GB of memory to be addressed, but this isn't 100 percent the same as having 4GB of physical memory.
What happens is that some of the addressable memory (regardless of how much you have physically installed) is reserved for use by page files or by some of the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc., so it's unavailable for use as normal main memory.
The amount of memory needed for these devices is calculated by your system at startup; if you haven't maxed out the memory in your system, it's invisible to you, and all your physical memory (the RAM that's installed) is available for use. However if you've maxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM.
The maximum memory limitation varies by operating system; for instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Memory maximums for current Microsoft® Windows OSs include:
  • Windows XP Home: 4GB
  • Windows XP Professional: 4GB
  • Windows XP 32-bit: 4GB
  • Windows XP 64-bit: 128GB
  • Windows Vista Home Basic: 4GB
  • Windows Vista Home Basic 64-bit: 8GB
  • Windows Vista Home Premium: 4GB
  • Windows Vista Home Premium 64-bit: 16GB
  • Windows Vista Ultimate: 4GB
  • Windows Vista Ultimate 64-bit: 128GB+
  • Windows Vista 32-bit: 4GB
  • Windows Vista 64-bit: 128GB+
May 23, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
